Save $13 and power up 2 devices at once with Anker's PowerCore 13000mAh portable charger
The Anker PowerCore 13000mAh 2-port compact portable charger has dropped to a sale price of $24.99 on Amazon today only. The low price is part of Amazon's Gold Box deals of the day, so it's very temporary. Usually this power bank is sold directly by Anker for around $38. We have never seen it go this low directly, and the last sale was a drop to $30 back in January.
Unfortunately the sale price only applies to the black colored charger as the other others, like Blue are still selling at the regular $38 street price. You can see how good this price is by just looking at some of Anker's other options. Even a slight upgrade to the 15000mAh battery charger would cost $15 more.
Anker Soundcore Life Q30 hybrid active noise-cancelling Bluetooth headphones
$59.99 $79.99 Save $20
These hybrid Bluetooth headphones reduce ambient noise up to 95% thanks to active noise-cancelling mics. The battery lasts up to 40 hours with ANC on or 60 hours with it off, and recharge via USB-C. Clip the $20 on-page coupon.
Anker Powerline II 6-feet USB-C to Lightning cable
$12.74 $15.00 Save $2
When using a USB-C power adapter (not included), you'll get the fastest possible charge for your iPhone. Plus you can seamlessly sync and charge your Mac. This is Apple MFi certified and lasts 12 times longer than other cables.
Anker Liberty Air 2 Pro true wireless earbuds Best Buy
$79.99 $130.00 Save $50
These earbuds have active noise-cancelling that's customizable with a simple app. You'll get a total of 26 hours of playtime with seven hours from a single charge and the rest from the charging case. Uses USB-C and has wireless charging.
Anker Soundcore Rave Neo portable Bluetooth speaker with LED lights
$84.99 $120.00 Save $35
Includes a rechargeable battery that will last for up to 18 hours and can charge other devices with the USB port. IPX7 rated for water resistance. The built-in LED lights will sync to the music you're playing. Connect multiple speakers together.
Anker Soundcore Liberty 2 Pro true wireless earbuds black
$49.99 $100.00 Save $50
They last for up to eight hours on a single charge with up to 32 hours total using the charging case. They have quick charge so you can get two hours after 10 minutes spent charging. They also charge via USB-C or a Qi wireless charger.
The 13000mAh battery is a large capacity and capable of charging all your smartphones several times over. Plug in any compatible devices using the two high-speed USB-A ports. Since both ports use PowerIQ and Voltage Boost technology, they will be able to detect exactly what device is plugged in and adjust accordingly. You'll always get the fastest possible speed for whatever device you're using, although the charger does not support things like Quick Charge.
It is also designed to be compact and portable, so you can fit it into your purse or backpack. The whole thing is only the size of a wallet, and it comes with a travel pouch. You'll get a micro USB cable for charging the device, and it's backed up by Anker's 18-month warranty. Users give it 4.6 stars out of 5 based on 7,267 reviews.
