Save $10 on TaoTronics' wireless charging air vent mount for your car
The TaoTronics air vent phone holder and 5W wireless charger is down to $8.99 with code JEJB6GU6 at Amazon. That price brings the mount down from $19, which is the price it has been going for since earlier this summer. Today's drop marks the lowest price we've seen, so it's a great deal for you.
The mount is simple to use. It's adjustable and works with any smartphone with a screen size between 2.3 and 3.5 inches. All you do is press your phone into the cradle and the arms will snap shut around it, gripping it into place. Press the simple release bars to get it out again.
Latest Videos From
The wireless charger provides 5W of output, which is compatible with pretty much all wireless charging smartphones, even if it's not the fastest possible option. The charging will work with cases, too, as long as they aren't more than 0.2 inches thick.
The mount uses rubber arms to grip onto the vent. They won't detach or fall even while you're driving over bumpy terrain. You can also rotate it from portrait to landscape, which allows you to find the perfect viewing angle.
Users give the mount 3.9 stars out of 5 based on 73 reviews.
