Save $10 on Anker's well-rated Soundcore Motion Q Bluetooth speaker
Bluetooth speakers come in all shapes and sizes, some of which are designed to be big and loud, and others to look really nice. Anker has done a great job of combining the features that people want with great sound quality and keeping it at an affordable price. Right now you can pick up the Soundcore Motion Q waterproof Bluetooth speaker for just $29.99 when you clip the on-page coupon. This saves you $10 compared to its normal price, and brings it to one of the best prices we've seen to date.
Anker Soundcore Life Q30 hybrid active noise-cancelling Bluetooth headphones
$59.99 $79.99 Save $20
These hybrid Bluetooth headphones reduce ambient noise up to 95% thanks to active noise-cancelling mics. The battery lasts up to 40 hours with ANC on or 60 hours with it off, and recharge via USB-C. Clip the $20 on-page coupon.
Anker Powerline II 6-feet USB-C to Lightning cable
$12.74 $15.00 Save $2
When using a USB-C power adapter (not included), you'll get the fastest possible charge for your iPhone. Plus you can seamlessly sync and charge your Mac. This is Apple MFi certified and lasts 12 times longer than other cables.
Anker Liberty Air 2 Pro true wireless earbuds Best Buy
$79.99 $130.00 Save $50
These earbuds have active noise-cancelling that's customizable with a simple app. You'll get a total of 26 hours of playtime with seven hours from a single charge and the rest from the charging case. Uses USB-C and has wireless charging.
Anker Soundcore Rave Neo portable Bluetooth speaker with LED lights
$84.99 $120.00 Save $35
Includes a rechargeable battery that will last for up to 18 hours and can charge other devices with the USB port. IPX7 rated for water resistance. The built-in LED lights will sync to the music you're playing. Connect multiple speakers together.
Anker Soundcore Liberty 2 Pro true wireless earbuds black
$49.99 $100.00 Save $50
They last for up to eight hours on a single charge with up to 32 hours total using the charging case. They have quick charge so you can get two hours after 10 minutes spent charging. They also charge via USB-C or a Qi wireless charger.
Right off the bat you'll notice that this speaker has a more elegant design than some of the others thanks to its fabric wrap. The top has a few buttons, including power, volume, play, and mute, and on the side there is even a place to attach a string so you can hang it from a tree or shelf. The speaker itself is IPX7 waterproof rated, so you can submerge it completely under water without anything happening to it.
It offers 360-degree sound from two full-range drivers and dual passive radiators. You can easily pair two of the speakers together for wireless stereo audio, and per charge the speaker will last about 10 hours. It weighs in at under a pound, so you'll have no trouble packing this on your next adventure to use it in the woods, on the river, or even by the pool. Anker backs this speaker with an 18-month worry-free warranty.
Jared started off writing about mobile phones back when BlackBerry ruled the market, and Windows Mobile was kinda cool. Now, with a family, mortgage and other responsibilities he has no choice but to look for the best deals, and he's here to share them with you.
