Save $10 and keep an eye on the road with the YI Nightscape Dash Cam
The Yi Technology Nightscape Dash Cam is down to $59.99 at Best Buy today only. That's a new low price for a dash cam that usually sells for around $80 there. This price even beats Amazon where you'll find it for around $63 using an on-page coupon. The sale is good for one day only as its part of Best Buy's deals of the day.
Yi 4K action camera and 3-axis gimbal stabilizer kit
$109.00 $199.00 Save $90
You can record up to 4K with 30fps or 1080p at 120fps. Capture 12MP photos. Use the electronic image stabilization tech and the gimbal to get perfect shots every time. Includes 360-degree omni-directional mics, Bluetooth, and high-speed Wi-Fi.
Four Yi 1080p W-Fi home security cameras
$89.00 $189.99 Save $101
$99.00 $189.99 Save $91
The dash cam comes with a 2.4-inch LED display with high clarity. It can record in 1080p at 60fps, and it has a 140-degree field of view, which means it can capture several lanes of traffic and wide angles. The dash cam is also powered by your car, so there's no battery to worry about. That helps make it more resistant to extreme temperatures. It can keep functioning between -22 degrees Fahrenheit and 185 degrees. You don't have to worry about overheating or batteries getting drained.
The Nightscape is named as such because it's got Sony STARVIS precise night vision built in. This internal imaging sensor provides excellent and colorful clarity and illumination even during really low lighting conditions. It combines six different lenses to focus the light and reveal details and contrasts.
The camera is easy to setup. You just plug it in and go. Plus, with apps on both Android and iOS, you can integrate very easily. The dash cam has built-in Wi-Fi for just that purpose. Use the app to share or backup recorded footage.
The Advanced Driver Assistance System is a built-in AI copilot that can detect and sound an alert to help you out. The things this system can detect are Fatigued Driver, Lane Departure, Front Collision, and more. After all, the last thing you want to do is be the cause of an accident. The dash cam even comes with a 32GB microSD card, which is necessary for recording video.
