Save $10 and keep an eye on the road with the Yi Nightscape Dash Cam
The Yi Technology Nightscape Dash Cam is down to $59.99 at Best Buy today only. That's a new low price for a dash cam that usually sells for around $80 there. This price even beats Amazon where you'll find it for around $62.99 using an on-page coupon. The sale is good for one day only as its part of Best Buy's deals of the day.
Yi indoor and outdoor security cameras and dash cams
Up to 38% off
The deals include individual cameras as low as $35, packages of up to 4 cameras you can place around your house, and cams that are good for both indoor and outdoor use. There's even a Yi 1080p dash cam on sale for $42.
Yi 1080p wireless outdoor security camera
$57.99 $80.00 Save $22
Supports microSD cards, but you can also use Yi's Cloud service to store recorded footage.
Yi 1080p outdoor security Cloud Camera
$59.99 $80.00 Save $20
It also has cloud storage for your footage, night vision, and smart notifications.
Yi 1080p wireless home camera 2-piece
$50.99 $70.00 Save $19
Look at that guy, he didn't even bring a bag to steal that laptop!
The dash cam comes with a 2.4-inch LED display with high clarity. It can record in 1080p at 60fps, and it has a 140-degree field of view, which means it can capture several lanes of traffic and wide angles. The dash cam is also powered by your car, so there's no battery to worry about. That helps make it more resistant to extreme temperatures. It can keep functioning between -22 degrees Fahrenheit and 185 degrees. You don't have to worry about overheating or batteries getting drained.
The Nightscape is named as such because it's got Sony Starvis precise night vision built in. This internal imaging sensor provides excellent and colorful clarity and illumination even during really low lighting conditions. It combines six different lenses to focus the light and reveal details and contrasts.
The camera is easy to setup. You just plug it in and go. Plus, with apps on both Android and iOS, you can integrate very easily. The dash cam has built-in Wi-Fi for just that purpose. Use the app to share or backup recorded footage.
The Advanced Driver Assistance System is a built-in AI copilot that can detect and sound an alert to help you out. The things this system can detect are Fatigued Driver, Lane Departure, Front Collision, and more. After all, the last thing you want to do is be the cause of an accident. The dash cam even comes with a 32GB microSD card, which is necessary for recording video.
