Samsung Galaxy A71 review: Samsung's best mid-range phone to date
(Image: © Apoorva Bhardwaj / Android Central)
Android Central Verdict
Bottom line: The Galaxy A71 builds on the success of last year's A70 with upgraded internals and a new 64MP camera that takes great photos. The design has been refreshed, you get incredible battery life with 25W fast charging, and the 6.7-inch AMOLED panel is one of the best in this category. As an overall package, the Galaxy A71 is one of the best mid-range phones you'll find today.
Pros
    Gorgeous design
    Vibrant AMOLED screen
    Excellent battery life with 25W fast charging
    Robust internal hardware
    64MP camera takes great photos
    One UI 2.0 out of the box
Cons
    Slow fingerprint sensor
    Macro camera is trash
Update, March 2021: Samsung Galaxy A71 review, one year later
From the very beginning, the Galaxy A series was meant to target the mid-range segment. But in 2019, Samsung diversified the series to include the budget segment as well, leading to devices like the Galaxy A10 and A20. Samsung streamlined its strategy, and the Galaxy A series now caters to both the budget and mid-range categories.
One of the best cheap Android phones to come out of the Galaxy A lineup was the Galaxy A70. It was the first Samsung phone to offer 25W wired charging and offered decent specs in the form of a Snapdragon 675. The Galaxy A71 builds on that formula with updates to the camera and chipset, and it also sports an exciting new design with a smaller cutout.
Samsung hasn't changed too much here from last year, but the updates make the Galaxy A71 an enticing option in the mid-range category. I'm reviewing the 4G version of the phone, but Samsung also sells a 5G-enabled version of the Galaxy A71 that's on sale in the U.S. and other global markets.
Samsung Galaxy A71 Price and availability
Source: Apoorva Bhardwaj / Android Central (Image credit: Source: Apoorva Bhardwaj / Android Central)
The Galaxy A71 is available globally, and Samsung sells it in two editions: a 4G-only model made for select countries like India and other parts of Asia as well as the UK, and a 5G version that is available for North America. The 4G version is powered by a Snapdragon 730 available with 8GB of RAM and 128GB of storage, and retails at ₹27,499 ($380).
Meanwhile, the 5G model is powered by the Snapdragon 765G or the Exynos 980 based on where you buy the phone, and in the U.S. the device currently retails for $445 for the variant with 6GB of RAM and 128GB of storage. Over in the UK, you'll be able to get your hands on the 4G variant of the Galaxy A71 for £419 ($580).
Both the 4G and 5G models are available in Prism Crush Black, Prism Crush Blue, Prism Crush Silver, and Haze Crush Silver.
Samsung Galaxy A71 Design and display
Samsung offered vibrant gradient designs last year across the Galaxy A series, and in 2020 it is making a few tweaks to the design. There's now a criss-cross pattern underneath the back that shows up as light reflects off the surface of the phone, and it is broken into quadrants. Each quadrant has a slightly different hue, and the overall effect is rather striking.
The Galaxy A71 has a gorgeous design that's backed up by robust internal hardware.
Of course, the phone is still sporting a polycarbonate back, but that isn't immediately evident. The gradient design combined with the glossy coating makes the back look and feel like glass, but because it is made out of plastic, it doesn't add too much weight to the device. Even though there's a 4500mAh battery under the hood and a 6.7-inch screen, the Galaxy A71 comes in at a very decent 179g. There's also the fact that a polycarbonate back makes the phone just that little bit more durable.
Another design change at the back is the rectangular camera housing. As we've seen on the rest of Samsung's portfolio — including the Galaxy A51 and the Galaxy S10 Lite — Samsung is sticking to a unified design theme in this area, and that means using the same camera housing as the Galaxy S20 series.
The Galaxy A71 has razor-thin bezels at the front, and there's now a hole-punch cutout for the front camera. The cutout itself is large, but it isn't too distracting, and like most phones in the market today, you get an in-screen fingerprint reader.
While Samsung abandoned the 3.5mm jack on its flagships, the analog port is still intact on the Galaxy A71. The power and volume buttons are located on the right side of the phone, and the positioning isn't too far up the side, allowing for easy access. There's a single speaker at the bottom on the other side of the USB-C charging port.
Overall, there's plenty to like when it comes to the design of the Galaxy A71. The polycarbonate doesn't diminish the vibrant hues and great in-hand feel, and the fit and finish is on par with the best that Samsung has to offer.
Samsung Galaxy A71 hands-on preview
Dominating the front of the Galaxy A71 is a 6.7-inch FHD+ (2400 x 1080) Super AMOLED display. The panel itself is largely unchanged from the A70, but that's not necessarily a bad thing. You still get a screen with vibrant colors, excellent sunlight visibility, and great viewing angles. The panel is protected by a layer of Gorilla Glass 3, just like last year's A70.
Even though the Galaxy A71 has a massive 6.7-inch screen, it is surprisingly easy to use one-handed.
The flowing curves at the back combined with the thin bezels make it easy to use the Galaxy A71 — you just don't get the feeling that you're using a phone with a 6.7-inch screen. For some context, this is the second-largest display that Samsung currently offers; only the Galaxy S20 Ultra with its 6.9-inch panel has a bigger screen.
The screen on the Galaxy A71 has excellent colors out of the box, and you can also adjust the color balance by switching to the Vivid mode in the phone's settings. As is the case with every other Samsung phone, you get a lot of customizability around font and text scaling. There's no notification LED here, but you do get a full-featured Always On Display, giving you an easy overview of pending notifications without having to wake the screen.
Like the design aesthetic, the display on the Galaxy A71 holds up well — this is one of the best screens you'll find in the mid-range category. Sure, it may not have a high refresh rate, but the panel quality itself makes up for that omission.
Samsung Galaxy A71 Hardware and battery
One of the reasons that made last year's Galaxy A70 stand out was the Snapdragon 675 chipset. The Galaxy A71 features updated internals in the form of the Snapdragon 730. Qualcomm's mid-range chipset is a stalwart in this category, and it is set to be the chipset of choice for Google's upcoming Pixel 4a.
Swipe to scroll horizontally
SpecsSamsung Galaxy A71
SoftwareOne UI 2.0 based on Android 10
Display6.7-inch (2400x1080) Super AMOLED
Chipset2.20GHz Snapdragon 730
RAM6GB/8GB
Storage128GB
Rear Camera 164MP ƒ/1.8 (primary)
Rear Camera 212MP ƒ/2.2 (wide-angle)
Rear Camera 35MP ƒ/2.4 (macro)
Rear Camera 45MP ƒ/2.2 (portrait)
Front Camera 132MP ƒ/2.2
ConnectivityWi-Fi 802.11 ac, BT5.0, NFC
Battery4500mAh | 25W
SecurityIn-screen fingerprint
ColorsPrism Crush Black, Silver, Blue
Dimensions163.6 x 76 x 7.7mm
Weight179g
The Snapdragon 730 debuted nearly two years ago and features two Cortex A76 cores clocked at 2.20GHz and six energy-efficient Cortex A55 cores that go up to 1.8GHz. It also has the Adreno 618 GPU, the Hexagon 688 DSP and is built on the 8nm node. The node shrink to 8nm allows the Galaxy A71 to deliver better battery life than its predecessor, and you also get better performance, particularly when gaming.
I didn't see any slowdowns whatsoever on the Galaxy A71, and the phone handled visually demanding games just fine. The Snapdragon 730 is a known quantity at this point — with phones like the Mi 9T, POCO X2, Mi Note 10, and several others featuring the chipset. It delivers reliable performance in day-to-day tasks and also doubles as a decent chipset for gaming.
The Galaxy A71 comes with 6GB of RAM and 128GB of UFS 2.1 storage as standard, and there's also a variant with 8GB of RAM and 128GB of storage. You get a MicroSD card that can slot in an SD card up to 1TB in size, and the global model comes with a dedicated dual SIM tray in addition to the MicroSD slot.
What's particularly interesting is that the Galaxy A71 variant sold in the U.S. is powered by the beefier Snapdragon 765 chipset. That's because of the fact that it has a built-in 5G modem, and with Samsung selling the device at carriers, it went with a 5G-enabled chipset. So if you are looking at buying the A71 in the U.S., know that you're getting a phone with outstanding performance.
While the Galaxy A71 has robust internals, one area where it falls short is the in-display fingerprint sensor. Although the phone uses an optical solution, it isn't quite as fast or reliable as other devices in this category. It usually takes around a second to unlock the phone, and I've had my fair share of errors when the sensor failed to recognize my fingerprint.
A standout feature on the Galaxy A71 is the battery life. With a 4500mAh battery under the hood, the phone easily manages to deliver over a day's worth of use consistently. I didn't have to worry about the phone running out of battery over the course of a day, and I routinely averaged over six hours of screen-on-time spread over 15 hours.
With reliable performance and outstanding battery life, the Galaxy A71 nails the basics.
And when you do need to charge the phone, there's 25W fast charging, with a 25W charger bundled in the box. You'll get up to a 50% charge from flat in just 30 minutes, and a full charge takes just over 80 minutes.
In terms of connectivity, the Galaxy A71 has Wi-Fi ac, Bluetooth 5.0 LE, A-GPS, and NFC. The phone has a Category 15 LTE modem with 3x carrier aggregation, and the global variant has the following LTE bands: 1/2/3/4/5/7/8/12/13/17/20/28/38/40/41/66. I tested the phone in India, and it delivered rock-solid connectivity over Wi-Fi. I didn't face any issues with calls either, and when it comes to the basics, the Galaxy A71 has zero problems.
There's no wireless charging or water resistance here, but if you're looking for a reliable phone for day-to-day use, the Galaxy A71 is a great choice.
Samsung Galaxy A71 Camera
The Galaxy A71 has a 64MP primary lens that's joined by a 12MP wide-angle shooter, 5MP macro lens, and a 5MP portrait lens. Other than the 64MP camera, the lens arrangement is identical to the Galaxy A51. The 64MP camera relies on pixel binning to produce 16MP shots by default, and there's a 32MP camera at the front for selfies.
The camera interface itself is identical to what you get on the Galaxy S20 series, with the shooting modes laid out in a ribbon. You can add more modes to the ribbon for easy access, and on the other side, you get toggles for a timer, settings, AR Doodle, flash, and beautifying effects.
Shots taken in daylight conditions come out with plenty of detail, offering great dynamic range and color vibrancy. There's little to no noise, highlights aren't blown out, and auto HDR does a great job bringing out detail in photos. The 12MP wide-angle camera does a decent job as well, producing shots with good detail — and, more importantly — accurate colors. The A71 also takes great portrait shots in Live Focus mode.
As you can probably imagine, the Galaxy A71 doesn't fare so well in low-light conditions. This is a constant theme in the mid-range segment, and as far as this category has come in the last three years, there aren't many sub-$500 phones outside of the Pixel 4a series that can take good low-light shots. The A71 takes decent enough shots, but you'll find a lot of noise when viewing the resultant photos on a monitor. The dedicated Night Mode does little to fix this particular issue, but you do get a better dynamic range and more detail.
Things so downhill from here. Like the Galaxy A51, the A71 has a 5MP macro lens that just isn't usable. It has a fixed focal length, so it is near-impossible to get it to focus on a subject. The effort that it takes is just not worth it when you consider that the few images that are actually in focus don't end up looking particularly great.
Samsung Galaxy A71 Software
The Galaxy A71 comes with One UI 2.0 based on Android 10 out of the box, and you get the same set of features as the Galaxy S20 series. As is usually the case with Samsung phones, there's more than enough customization on offer, and it usually takes an hour or so to set things up just the way you want.
The Galaxy A71 delivers a software experience that's identical to Samsung's flagships.
You get to pick between Android 10's navigation gestures and Samsung's own system, there's a built-in screen recorder, enhanced system-wide dark mode, an Edge screen with configurable panels, Link to Windows, Samsung Pass, Game Booster, and so much more. There's also a software-assisted face unlock, but like the in-screen sensor, it isn't quite as reliable as what you get on other devices.
The Galaxy A71 also delivers a full-fledged Samsung Pay experience. Samsung's mobile payments service continues to be the best around, and the fact that it works with NFC machines and older MST card readers gives it an edge. The Galaxy A71 wouldn't be a Samsung phone if it didn't have bloatware, and you find the usual Microsoft services, a social network that you've never heard of called Helo, DailyHunt, and others. The good news here is that you can easily uninstall all the bloatware.
With Samsung's new software commitment, the Galaxy A71 will receive three platform updates along with three years of security updates. It's fantastic to see Samsung make positive strides in this particular area, and it makes the A71 a much more enticing choice.
Samsung Galaxy A71 The competition
Google Pixel 4a
Source: Andrew Martonik / Android Central (Image credit: Source: Andrew Martonik / Android Central)
The obvious contender to the Galaxy A71 is the $350 Pixel 4a. The phone misses out on 5G connectivity and has modest hardware in comparison to the A71, but the camera on offer beats every other device in this segment. So if camera quality is a higher priority than a large screen or two-day battery life, the Pixel 4a is a better fit for your needs.
If you want a phone with 5G connectivity and high-end hardware, the $650 OnePlus 8T is a fantastic option right now. You get a 90Hz AMOLED display, the latest hardware available today, refined software, and fast updates — the phone is already running Android 11.
Samsung Galaxy A71 Should you buy?
You should buy this if ...
  • You want a phone with a vibrant AMOLED screen and a modern design
  • You're looking for a device with a large battery that lasts two days
  • You want a phone that will get regular software updates
You should not buy this if ...
  • You want a compact phone
Samsung didn't make a lot of changes with the A71, but it didn't need to. The Galaxy A70 continues to be a great phone, and by updating the internal hardware and adding a 64MP camera, Samsung has added enough differentiation to make the Galaxy A71 stand out in 2020.
The Galaxy A71 has everything you're looking for in a mid-range phone.
The Galaxy A71 5G is available in the U.S. for $500, making it a stellar option if you're in the market for a 5G-enabled device.
Overall, the Galaxy A71 offers fantastic value for what you end up paying for the phone. The Snapdragon 730 is a powerful mid-range chipset that will deliver a lag-free usage experience for several years, and the design should similarly hold up. You also get excellent battery life with 25W fast charging, One UI 2.0 with Android 10, and three guaranteed platform updates, and that 64MP camera isn't all that bad either.
4.5 out of 5
The 4G-enabled variant of the Galaxy A71 is a great phone in its own right, but the Galaxy A71 5G takes things to the next level with beefier hardware and global 5G connectivity. If you're used to Samsung's phones and don't want to switch to a different brand, the Galaxy A71 will serve you well for several years.
Samsung Galaxy A71 12 months later review
A year after its launch, the Galaxy A71 continues to be a great mid-range choice, particularly in the U.S. The 5G-enabled variant is one of the most powerful phones in its segment, and the fact that it is now available for $499 makes it an enticing value.
The screen also holds up just as well, but it's the battery that differentiates the Galaxy A71 in 2021. With a large battery and 25W fast charging, you're guaranteed two days' worth of battery life from a full charge.
Samsung has done a remarkable job with software updates. The Galaxy A71 made the switch to One UI 3.1 based on Android 11 at the end of February 2021, receiving all the new software features that Samsung has to offer. The phone is guaranteed to receive three Android updates, so it will pick up Android 12 and Android 13 once that becomes available down the line.
Samsung is now delivering four years of security updates, and the Galaxy A71 is included in the list, so if you're planning on buying a phone that will hold up for three or more years, you don't have to worry about missing out on updates.
With the imminent arrival of the Galaxy A72, the Galaxy A71 should see a significant discount in the coming months. That should make the device a great option if you're looking at a value-focused 5G phone in 2021.
Harish Jonnalagadda
Senior Editor - Mobile
