Bring SainSonic's EVOPIX 15.6-inch Portable Touchscreen Monitor with you at a $80 discount
Ever wish you had a portable second monitor to connect your laptop to while on-the-go? The SainSonic EVOPIX 15.6" Multi-Touch Full HD Portable Monitor could be just what you're dreaming of, and today it's on sale for only $199 at Woot. Though it's currently discounted to $249 at Amazon, it normally sells for $279 there and hasn't ever fallen this low before. This sale is set to last for just one day only, so don't miss your chance!
Shipping at Woot is free for Amazon Prime members. If you're not a member yet, starting a free 30-day trial will help you skip Woot's $6 shipping fee too.
SainSonic EVOPIX 15.6-inch Multi-Touch Full HD Portable Monitor
$159.00 $174.89 Save $16
$169.00 $279.00 Save $110
$179.99 $279.00 Save $99
This ultra-slim 15.6-inch Full HD monitor is designed for use with USB-C laptops, though it also includes a Mini HDMI port to connect with laptops that don't feature a USB Type-C port. It's equipped with an IPS panel with Flicker-free technology and a 1920x1080 resolution. It allows for a 178-degree viewing angle and comes with a premium magnetic foldable smart case to protect it from dust and scratches. The case also makes it simple to prop the monitor up without needing help from some random book or box next to you. It's small enough to keep in your briefcase or backpack like a tablet, and it's even touch-enabled with 10-point multi-touching functionality and an oleophobic layer to keep it from getting dirty from fingerprints.
SainSonic's EVOPIX monitor also supports up to 100W power delivery so you can use it as a power dock while it's connected to a USB-C computer. It could be a good fit to use with the Nintendo Switch too.
