These U-shaped USB-C cables are just $6.49 and stay out of your way while charging your phone
Using your phone while it's plugged in and powering up can be a hassle with your charging cable in the way. That's why Rock Space's Angled USB-C Cable was created. In an effort to keep your cable out of your way while charging, these USB-C cables are equipped with a right-angled connector so that the cord is pulled behind your phone while it's plugged in, making it much easier to browse the Internet or game with. While they're normally affordably priced at $9.99 each, today you can score one at Amazon for just $5.99 when you first clip the coupon on its product page and then enter promo code 5KK4MX5J during checkout. At 40% off its regular cost, today's discount brings this cable lower than it's ever reached without coupons before.
Rock Space USB-C to USB-A Cable (3-foot)
Latest Videos From
$4.99 $9.99 Save $5
These 3.3-foot USB-C to USB-A cables feature a special 180-degree connector that keeps the cable out of your way while it's plugged into your device. They're extremely durable too, and suitable for both charging and data transfers.
$4.99 $9.99 Save $5
The unique design allows the cable to sit behind your phone as it charges so you can keep using it without holding it in an odd position. This braided cable is meant to last, so be sure to enter the code below at checkout to snag this low price.
Rock Space water-resistant true wireless earbuds
$24.99 $50.00 Save $25
The deal takes about 50% off the price, and these are great looking earbuds that sound good and feel better.
Rock Space's unique 180-degree U-Type design makes charging your phone much more convenient while it's in use. Its high-quality nylon-braided cable has an aluminum alloy casing which can outlast over 10,000 bends based on testing. The cable is capable of syncing data too at up to 480Mb/s, and there are also built-in protections to ensure your devices don't overheat. It measures three feet long and works with all USB-C devices, even the Nintendo Switch!
A 12-month warranty is included with today's purchase in case you experience any issues with the cable you receive. Don't forget to use both its on-page coupon at Amazon and the promo code above during checkout to ensure you score the best price possible on this product.
