When it comes to stick vacuums, the Roborock H6 is one powerful contender
Roborock might be one of the best names in the robot vacuum market, but it's also becoming a prominent name to consider in hand-held vacuums, too. The Roborock S6 MaxV and S6 Pure might be the company's latest robots to clean your floors, but the Roborock H6 is the handheld stick vacuum that helps clean all the other places in your home (and beyond).
The Roborock H6 combines high performance with thoughtful features and helpful extras, giving it an edge in the stick vacuum market. The vacuum includes many attachments that make it capable of cleaning all around the home and has powered brushes and rollers that can make it even more effective than you might expect.
Lightweight without sacrificing power or longevity
The Roborock H6 is impossibly light for how much power is packed under the hood. With a battery that lasts 90 minutes and suction power on-par with a traditional vacuum cleaner, it's something no home can go without.
At the heart of the Roborock H6 is a powerful vacuum. The motor is capable of generating 150AW of suction power, which is enough to suck up small particles and even pull mites out of furniture. Inside the vacuum, a series of filters will capture the debris, trapping particles as small as 0.3 microns, so it's not just your house that's clean but also the air inside of it.
All that power comes from a Lithium-Ion Polymer battery, the first of its kind in a stick vacuum. With that battery, the H6 can run for up to 90 minutes on its Eco mode, letting you tackle light cleaning all around the house. Or, you can run the vacuum at maximum power for up to 10 minutes of heavy-duty cleaning.
You won't have to worry about replacing the battery either, as it can maintain 80% of its original charge even after 400 charging cycles. While cleaning, the Roborock H6 can detect carpeting and automatically boost the suction power. Paired with the carpet brush powered by a 50W motor, this vacuum is ready to clean out debris that's buried deep. It can do the same for furniture, too, thanks to an included mini-brush that's also motorized.
Between its many attachments, its powerful suction and battery, and its three-pound design, the Roborock H6 is suited to cleaning high and low. All the more impressive that it costs just $450 for the whole package.
You can learn more about the Roborock H6 here.
Be an expert in 5 minutes
