Redmi Note 10 Pro Max review: The budget phone to beat in 2021
(Image: © Apoorva Bhardwaj / Android Central)
Android Central Verdict
Bottom line: The Redmi Note 10 Pro Max combines a sublime 120Hz AMOLED panel with reliable hardware, a great 108MP camera, large 5020mAh battery with 33W fast charging, Android 11 out of the box, and a gorgeous new design. If you're in the market for a new budget phone, you cannot go wrong with the Redmi Note 10 Pro Max.
Pros
    Stunning 120Hz AMOLED panel
    108MP camera holds its own
    Gorgeous new design
    Outstanding battery life
Cons
    MIUI still needs work
    No NFC
    Lack of 5G could be an issue globally
    4K recording limited to 30fps
The most important phone launch in India isn't from Samsung, Vivo, Realme, OPPO, or even OnePlus. That particular honor belongs to the Redmi Note lineup. The series has defined the budget category over the last five years, with Xiaomi racking up 200 million sales in that time.
But what's particularly interesting is just how many phones Xiaomi sold in the last 15 months. It took the brand over three years to hit the 100 million milestone, but just 15 months to sell another 100 million units — averaging sales of 7 million a month around the world. It's no wonder, then, that the Redmi Note 9 was one of the best-selling phones globally in 2020 and the standard for the best cheap Android phones.
In 2021, Xiaomi is taking things to the next level with the Redmi Note 10 series. The phones now come with AMOLED screens as standard, and the Redmi Note 10 Pro Max has a 108MP camera — a first in this series. All three phones also feature MIUI 12 based on Android 11 out of the box, sport massive batteries with 33W fast charging, and even offer IP52 water resistance.
More than anything else, the Redmi Note series democratizes high-end features. And right now, no device does that better than the Redmi Note 10 Pro Max. Here's what you need to know about the phone, and why it may just be the ideal choice if you're looking for a phone under ₹20,000 ($275) in 2021.
About this review
I'm writing this review after using the Redmi Note 10 Pro Max for five days in Hyderabad, India. The phone was connected to Jio's 4G network, ran MIUI 12.0.3 out of the box, and did not receive any software updates during the testing window. Xiaomi India provided the unit to Android Central for review.
Redmi Note 10 Pro Max Price and availability
Source: Apoorva Bhardwaj / Android Central (Image credit: Source: Apoorva Bhardwaj / Android Central)
The Redmi Note 10 Pro Max is now available in India, and it will make its way to other countries shortly. The EU and UK are key markets for Xiaomi, and if history is any indication, the Redmi Note 10 series should be available in the region within two months. The same device will be sold as the Redmi Note 10 Pro in global markets.
Xiaomi is selling three variants of the Redmi Note 10 Pro Max in India: the base version with 6GB of RAM and 64GB of storage costs ₹18,999 ($260), the 6GB/128GB model retails at ₹19,999 ($275), and the 8GB/128GB version is available for ₹21,999 ($300).
Redmi Note 10 Pro Max Design and screen
The fact that Xiaomi is bringing a 108MP sensor to the budget segment is noteworthy in and of itself, but what's just as exciting is the design of the Redmi Note 10 Pro Max. Xiaomi is following a similar design aesthetic as its Mi 11 flagship, and that makes the Redmi Note 10 one of the best-looking budget phones you'll find today.
The Redmi Note 10 Pro Max has a gorgeous design, and it's lighter and thinner than its predecessor.
Xiaomi calls this the Evol design language, an evolution of the Aura design that debuted two years ago on the Redmi Note 7 series. The Redmi Note 10 Pro Max has a frosted glass back with a subtle gradient on the Vintage Bronze color variant, and the design makes the phone stand out a lot more than its predecessors. The rear glass pane is protected by a layer of Gorilla Glass 3.
You'll find rounded edges and the same smooth curves at the back where the glass meets the mid-frame, and the device ends up looking rather elegant. Xiaomi didn't go overboard with labels — unlike Realme — with the Redmi branding located at the bottom.
The key design feature at the back is the camera module; the aluminum housing features a camera island that holds the four sensors — with the primary 108MP lens getting a chrome accent for added design flair — and the LED flash as well as the autofocus modules are located on the aluminum pane.
The camera housing is busier than the Mi 11, and the module itself protrudes considerably from the chassis, and that makes using the Redmi Note 10 Pro Max on a flat surface highly irritating. I usually just have phones sitting on my desk and interact with them while they're laying flat on the surface, but I couldn't do that with the Redmi Note 10 Pro Max because of the constant wobble. If you're thinking of picking this phone up, you should invest in a case to counteract the wobble from the camera housing.
Continuing on the design side of things, the Redmi Note 10 Pro Max has a side-mounted fingerprint reader on the right that's built into the power button. The button now sits flush with the frame, unlike previous generations where there was an indent. The sensor itself is unerringly accurate and fast to authenticate, and you can customize it with gestures — a double tap lets you launch the camera, switch to silent mode, turn on the flashlight, take a screenshot, or more.
The volume buttons are located above the power button, and on the left side of the frame is where you'll find the SIM card slot. Xiaomi is offering a full-width slot that lets you add two SIM cards as well as a microSD card should you wish to do so. Up top you'll find a 3.5mm jack as well as the IR blaster, and the secondary speaker. The primary speaker is at the bottom, and sits to the right of the USB-C charging port.
Last year's Redmi Note 9 Pro Max was one of the biggest and heaviest phones in this category, and Xiaomi is making amends this time around; the Redmi Note 10 Pro Max is 0.7mm thinner and 16g lighter than its predecessor while still offering a 5020mAh battery.
The lighter and thinner design make the Redmi Note 10 Pro Max significantly easier to use than its predecessor, and the subtle curves at the back where the glass panel joins the mid-frame also make a difference. The mid-frame itself has a glossy finish and is available in the same color as the back panel, and is made out of plastic.
Xiaomi is offering the phone in interesting color options this time: Vintage Bronze is my favorite model, with the phone featuring an orange gradient that looks fabulous. There's also Glacial Blue, and the standard Dark Night if you don't like flashy designs. All three colors may not be available at launch, so if you like the look of the Vintage Bronze variant, you may want to wait.
Redmi Note devices have a legacy of large displays with vibrant panels, and the Redmi Note 10 Pro Max comes with an AMOLED display — a first for the series. What's more exciting is that Xiaomi has added 120Hz refresh rate as standard, making the Redmi Note 10 Pro Max stand out from its rivals. The panel comes with a pre-installed screen protector, and it is coated with a layer of Gorilla Glass 5.
The 6.67-inch screen has a resolution of 2400 x 1080, and the panel itself is the best you'll find in this segment. It has excellent colors out of the box, and you can customize the color balance to your preferences, with Xiaomi offering three modes: Auto, Saturated, and Standard. You also have the option to manually adjust the color temperature if you want to switch to warmer or cooler colors.
The 120Hz AMOLED panel is the best you'll find in this category — it makes a huge difference.
It also gets very bright — I had zero issues using the screen in harsh sunlight. You also get HDR10 as well as Widevine L1 DRM, and there are no issues with streaming 1080p content from the likes of Netflix or Prime Video. Another standout with the Redmi Note 10 Pro Max is the stereo sound, and the device even has identical speakers at the top and bottom — a true stereo configuration.
The switch to 120Hz AMOLED makes using the Redmi Note 10 Pro Max that much more enjoyable. Everything from scrolling through social media to browsing content on Chrome or playing games is a delight, and while there are select few games that take full advantage of the 120Hz refresh rate, more and more titles are being added to the list.
You get the ability to switch between 60Hz or 120Hz — 60Hz is selected by default out of the box — and while Xiaomi has a nifty adaptive refresh rate tech on devices like the Mi 10T Pro, it hasn't introduced the same feature here. Xiaomi says that it is still fine-tuning the tech for AMOLED panels, so it may show up on future devices.
Finally, you can set up always-on display on the Redmi Note 10 Pro Max, and you'll find plenty of customizability. You get a lot of clock styles to choose from, and you can even set up your own. There's edge lighting as well — it's similar to what you'll find on the Galaxy S21 series, with the edges of the panel lighting up when you receive a notification.
Redmi Note 10 Pro Max Performance and battery
Xiaomi took a leaf out of Samsung's playbook and started reusing parts across its budget portfolio three years ago. The result is that a lot of phones in the Redmi, POCO, and the Mi series have identical hardware.
That's true of the Redmi Note 10 Pro Max as well. The phone offers the same Snapdragon 732G chipset as the POCO X3, and features a 108MP camera from the Mi 10i. The new addition here is the 120Hz AMOLED panel, but the rest of the hardware itself is immediately familiar.
Swipe to scroll horizontally
SpecsRedmi Note 10 Pro Max
SoftwareMIUI 12 based on Android 11
Display6.67-inch (2400x1080) 120Hz AMOLED
Chipset2.30GHz Snapdragon 732G
RAM6GB/8GB
Storage64GB/128GB
Rear Camera 1108MP ƒ/1.9 (primary)
Rear Camera 28MP ƒ/2.2 (wide-angle)
Rear Camera 35MP ƒ/2.4 (macro)
Rear Camera 42MP ƒ/2.4 (portrait)
Front Camera16MP ƒ/2.2
ConnectivityWi-Fi ac, BT5.1
Battery5020mAh | 33W
SecuritySide-mounted fingerprint
ColorsVintage Bronze, Glacial Blue, Dark Night
Dimensions164.5 x 76.1 x 8.1mm
Weight192g
So let's start with the chipset. The 8nm Snapdragon 732G is a known quantity in this segment, and it delivers reliable performance. It has two Cortex A76 cores that go up to 2.3GHz, and six energy-efficient Cortex A55 cores that go up to 1.8GHz.
This isn't the fastest chip you'll find in the budget segment — the Dimensity 800U delivers much more — but it is on par with most devices in this category, and Xiaomi did a good job optimizing it for MIUI. I didn't see any slowdowns in day-to-day use, and most games run fine, with intensive titles switching to medium settings. Xiaomi is leveraging Qualcomm's Elite Gaming features for jitter-free gaming.
Continuing with the hardware, the Redmi Note 10 Pro Max has Wi-Fi ac connectivity, Bluetooth 5.1, and an upgraded vibration motor that delivers much better haptic feedback. It's always great to see budget phones with good haptics, and that is the case here.
The Redmi Note 10 Pro Max is available in three configurations in India — 6GB/64GB, 6GB/128GB, and 8GB/128GB — and all three models feature LPDDR4X RAM and UFS 2.2 storage modules as standard. Xiaomi is also selling a Redmi Note 10 Pro with a 64MP Samsung primary camera, with all other hardware features being the same.
What's particularly interesting is that the Redmi Note 10 series comes with an IP52 rating, giving the phones a decent level of protection against dust and water ingress. Xiaomi hasn't really bothered about water resistance on its phones — the Mi 11 flagship does not have an IP rating — so it is good to see that things are changing in this area.
One of the ways Xiaomi is able to bring down costs of the Redmi Note 10 Pro Max is by limiting the number of LTE bands on the device. The phone has bands 1/3/5/7/8/40/41, and while it works on all 4G carriers in the country, you won't be able to access LTE in most global markets.
Then there's the fact that the Redmi Note 10 Pro Max misses out on 5G connectivity. That's not a big deal at all considering India won't have usable 5G for at least a few years, so you are not missing out on anything here. 5G has been paraded as a buzzword for the better part of 18 months now, and while the standard is taking off in the U.S. and UK, it is pointless to have a 5G phone in India in 2021.
There's no 5G here, but that won't be a problem in India for a few years.
The Indian government will auction 5G frequency in the 3.3 to 3.6GHz range sometime later this year, and we should see 5G trials from Airtel and Jio shortly thereafter — and no, Airtel's feasibility test does not count. The only beneficiary of 5G — at least as it pertains to the Indian market — is Qualcomm, with the vendor leveraging the upcoming standard to increase the licensing fee of its chipsets.
Even if you're interested in the Redmi Note 10 Pro Max as a long-term purchase and want to use the device for two or three years, the lack of 5G should not be a problem. For one thing, once 5G does become available to consumers, it will be significantly costlier than 4G because Airtel and Jio will be looking to regain the considerable investment that they put into acquiring the frequency. And because India is going with Sub-6 connectivity by default, you may not even see any tangible gains over 4G initially.
On the battery side of things, the phone has a massive 5020mAh battery with 33W fast charging. And yes, Xiaomi is bundling a 33W charger in the box. Redmi Note series has stood for battery life, and it is great to see Xiaomi offering the same battery size as last year in a chassis that's lighter, thinner, and significantly easier to use.
The phone delivers well over a day's worth of use from a full charge, even with the 120Hz mode selected. I haven't tested the battery life as thoroughly as I would've liked, but there shouldn't be any issues in this particular area. And when you need to charge the phone, it takes 30 minutes to go from zero to 50%.
Redmi Note 10 Pro Max Cameras
A standout feature on the Redmi Note 10 Pro Max is the 108MP camera at the back. The phone uses the same Samsung HM2 imaging sensor as the Mi 10i, and that makes it a considerable upgrade over its predecessors. There's also an 8MP wide-angle lens with 119-degree field of view, 5MP macro lens that's actually usable (which was a first for me), and a 2MP portrait lens. Up front you'll find a 16MP camera with a fixed focus.
Xiaomi leverages 9-to-1 pixel binning to deliver 12MP shots from the 108MP lens, and you get the option to take full-res photos as well. The camera interface itself should be familiar if you've used MIUI in the past, with all the shooting modes and toggles easily accessible. You get a Pro mode with the ability to tweak settings manually, and there's a dedicated Night Mode 2.0 that now shoots in RAW — it takes a series of images and interlaces them together to deliver detailed shots in low-light conditions.
The downside here is that the Night mode is limited to the primary lens — you won't be able to use it with the 8MP wide-angle module. You also miss out on the ability to record 4K footage at 60fps, with the phone limited to 30fps. There's 1080p at 60fps and 720p at up to 960fps, but Xiaomi is once again limiting 4K at 60fps to its mid-range and flagship devices.
The Redmi Note 10 Pro Max takes outstanding photos in daylight conditions, but that's a given. You get excellent detail, true to life colors, and wide dynamic range without any loss in detail. The camera also does an incredible job in low-light conditions, delivering vibrant shots with low noise levels.
Shadows are turned down for low-light shots, so you miss some of the finer details, but the caliber of photos you're getting here is astonishing. Of course, the dedicated Night mode does a much better job in low-light conditions, eking out more detail and delivering better colors.
The 8MP wide-angle lens takes detailed photos in daylight conditions, but colors tend to skew warmer. And the fact that you can't use the Night mode here limits its use in low-light scenarios. The 5MP macro lens has autofocus, and it does a decent job taking photos of subjects that are within 10cm. These shots tend to be noisy, but you still get a lot of detail.
Overall, the Redmi Note 10 Pro Max has one of the best cameras you'll find in this category. You get standout photos in any lighting scenario, and while it's not suited for 4K video, if you're primarily looking to shoot photos, you will love what this phone has to offer.
Redmi Note 10 Pro Max Software
The Redmi Note 10 Pro Max runs MIUI 12 based on Android 11 out of the box, giving it a leg up over recent Xiaomi launches like the Mi 10i or the POCO M3, which are still on Android 10.
Right off the bat, the first thing you'll notice about the Redmi Note 10 Pro Max is that there's not as much bloatware as its predecessors. Xiaomi is making a commitment to clean up MIUI, and has stated that it will get rid of the ads and spam notifications in MIUI 12.5, and give users the ability to uninstall several system apps.
Xiaomi removed a lot of bloatware already, and MIUI 12.5 will get rid of all the ads.
That's a welcome change, but MIUI 12.5 won't be available for at least a few months. So for now, you do get spam notifications, and they start just as soon as you finish setting up the device. Xiaomi's GetApps app store is particularly persistent at this, giving you constant "recommendations" on apps to install. All of that should go away with MIUI 12.5, and while you won't be able to uninstall GetApps with the update — Xiaomi considers it a key system service — it shouldn't bombard you with notifications.
Even without the changes, the Redmi Note 10 Pro Max offers a cleaner and less annoying software experience versus last year's Redmi Note 9 series. MIUI 12 has a lot of exciting changes, including floating windows, a privacy dashboard, new animations throughout the interface, schedulable dark mode, and it comes with an app drawer out of the box.
And with Android 11 under the hood, you get all the new additions built into the software, including the Conversations view, privacy and security features, media player in the settings tile, and the smart home controls. To use these smart home controls, you will need to switch to the new Control Center layout for the notification pane, with Xiaomi offering an iOS-style split notification pane.
Back in 2019, Xiaomi made the decision to switch its global Mi-branded phones to Google's dialer and Android Messages in lieu of its own offerings. It built on that last year, with all Mi phones sold outside China featuring Google's suite out of the box, and the change extended to POCO's devices as well, including the budget POCO M3.
With the Redmi Note 10 Pro Max, Xiaomi is bringing the Google dialer to the Redmi Note series. All three phones in the Redmi Note 10 series feature Google dialer and Android Messages as the default option for calling and texts. Xiaomi initially claimed in a briefing that it would retain the MIUI dialer in its Redmi phones, but seeing as how the devices don't have Xiaomi's dialer, that isn't the case.
While it's great to see standardized features coming to the Redmi Note series, there are a few software annoyances. The default keyboard out of the box is Xiaomi's own option instead of Gboard, so you'll have to go into settings once you finish setting up the phone to change it. And when you select dark mode, MIUI has an annoying habit of inverting colors for apps that don't have a dark mode yet, so you'll have to manually go into the settings and disable the feature for individual apps.
But on the whole, the Redmi Note 10 Pro Max fares much better than its predecessors. The software situation on the phone is decent right now, with the potential to get much better in the future — which isn't something I usually say about Xiaomi phones. It is great to see the manufacturer tackle long-standing issues with ads and bloatware in the UI, and that makes the Redmi Note 10 Pro Max that much more enticing.
Redmi Note 10 Pro Max The competition
The obvious alternative to the Redmi Note 10 Pro Max is Xiaomi's own Mi 10i. The phone has the same 108MP camera and delivers the same caliber of photos, and also has a gorgeous design with a 4820mAh battery and 33W fast charging. The key difference is that it is rocking a 120Hz LCD screen, runs Android 10 out of the box, but you get 5G connectivity. The base 6GB/64GB model starts off at ₹20,999 ($290), just ₹2,000 ($30) more than the Redmi Note 10 Pro Max.
If you're looking for a budget phone with a 120Hz panel and 5G connectivity, Realme's Narzo 30 Pro is also a decent option in this category. The phone has a 120Hz LCD panel, 5000mAh battery with 33W fast charging, and is powered by the Dimensity 800U — the same chipset as the Realme X7 and the Redmi Note 9T — with 5G connectivity and a 48MP camera at the back. The fact that all of this is available for just ₹16,999 ($235) means you're getting a great overall package.
If you need the best value in this category, the POCO X3 has the same Snapdragon 732G chipset as the Redmi Note 10 Pro Max but with a 120Hz LCD panel and 64MP camera at the back. You also get a massive 6000mAh battery with 33W fast charging and Android 10 out of the box, with the phone available for just ₹14,999 ($205) — a full ₹4,000 ($60) less than the Redmi Note 10 Pro Max.
Redmi Note 10 Pro Max Should you buy?
You should buy this if ...
You want a 120Hz AMOLED screen
The marquee feature on the Redmi Note 10 Pro Max is the 120Hz AMOLED screen. The high refresh rate screen makes it that much more enjoyable to use the phone on a daily basis, and paves the way for other budget phones to do the same going forward. Oh, and the stereo sound is a great new addition too.
You need a phone with outstanding battery life
Xiaomi has somehow managed to retain a 5020mAh battery while making the Redmi Note 10 Pro Max lighter and thinner than its predecessor. That makes a huge difference when you're using the phone, and you get the same great battery life as last year. This is a phone that will deliver more than a day's worth of use without any issues, and it has a 33W fast charger in the box.
You want a great camera
The Redmi Note 10 Pro Max has a 108MP camera that takes outstanding photos in most lighting conditions. It is the best sensor that you'll find in the budget segment, so if you need a phone with a standout camera, this is the one to get.
You need a phone that nails the basics
The Redmi Note 10 Pro Max has a 3.5mm jack, IR blaster, microSD slot, robust internal hardware, and a gorgeous design with exciting new color options.
You should not buy this if ...
You want clean software
Xiaomi has promised to clean up MIUI and get rid of ads in the UI with MIUI 12.5, but you'll have to wait for that particular update to show up later this year. The interface is better than last year's Redmi Note 9 Pro Max and it's great to see that the phone runs Android 11 out of the box, but there is still a learning curve here.
You need a camera for 4K video
The 108MP camera on the Redmi Note 10 Pro Max is one of the best you'll find in this category, but like other budget phones, you miss out on the ability to record 4K at 60fps. Stabilization is also limited to 1080p, so if you're in the need of a phone primarily for video, the Redmi Note 10 Pro Max doesn't offer quite as much here.
With the base version of the Redmi Note 10 Pro Max available for ₹18,999, Xiaomi is inching ever closer to the mid-range segment. You still get a lot of value for what you're paying here, but the fact that the phone costs over ₹15,000 may be a deal-breaker for a subset of the community.
That's where the Redmi Note 10 Pro comes in; the phone has the same 120Hz AMOLED screen and identical hardware, but switches out the 108MP camera for a 64MP module, and retails for ₹15,999, making it a much more enticing option in the budget category.
4.5 out of 5
Regardless of whatever model you go with, you're getting a few features as standard: a vibrant AMOLED display that's a delight to use, reliable performance, stellar battery life with 33W fast charging, Android 11 out of the box, great cameras, and an exciting design. There's not much more you could ask from a budget phone in 2021.
Harish Jonnalagadda
Senior Editor - Mobile
