Recharge anywhere with RAVPower's 20000mAh Solar Power Bank at over 40% off
Having an external battery on hand is always a good idea, but what happens when you're in the middle of the woods on a hike, your phone is dead, and you forgot to charge your power bank? If you're the proud owner of a RAVPower 20000mAh Solar Power Bank, you pop it in the sun for a while and you're good to go.
Though this model regularly sells for $40, today at Amazon you can pick one up for only $22.99 when you clip its on-page coupon and then use promo code G67CRIXL during checkout. That's more than 40% off the typical cost, and you'll be just over the threshold to get free shipping as well. You can choose from either Black or Orange, though only the Black model drops this low in price. The Orange version falls to $26.99 using the same promo code at checkout.
RAVPower 65W 4-port USB Desktop Charging Station
$34.99 $49.99 Save $15
Keep USB ports close by with this 65W USB Desktop Charging Station by RAVPower. It's equipped with two USB-C ports as well as two USB-A ports. Clip the coupon on its product page and use the following code at checkout to save $15.
RAVPower 10000mAh portable charger dual USB power bank
$9.99 $15.00 Save $5
The ultra slim power bank is only 15mm deep, so it's extremely portable. The battery size of 10000mAh is enough for a full charge of even the largest phones. Can charge two devices at once and has built-in safety features to protect them all.
RAVPower 61W Power Delivery 3.0 USB-C 2-port wall charger
$23.39 $30.00 Save $7
Has 61W output with Power Delivery 3.0. Can charge a MacBook in 2.1 hours. Can detect what's plugged in and deliver fastest possible speeds. Wants to be portable with slim, compact design and foldable pins. Includes built-in safeguards.
RAVPower 48W USB-C Car Charger with Power Delivery 3.0 and Quick Charge 3.0
$14.99 $19.99 Save $5
RAVPower's fast dual-port car charger features a 30W Power Delivery 3.0 USB-C port along with an 18W Quick Charge 3.0 USB-A port. Clip its on-page coupon to snag this deal.
RAVPower 25000mAh solar phone charger outdoor portable charger
$21.99 $46.00 Save $24
Use sunlight to recharge this charger's batteries or plug it in via micro USB or USB-C. The 25000mAh capacity is enough to keep all your devices going outdoors. Includes an LED flashlight and SOS mode for emergencies. Waterproof and dust proof.
This durable and sturdy charger is built to be rugged, with rubberized edges and IPX4 water resistance. It features two 2.4A USB ports and a built-in flashlight to help you see or be seen more clearly. There are also built-in safeguards to protect your phone from overcharging, short-circuiting, and other non-ideal situations. It does take quite a long time to fully recharge this using only the sun. About a week, in fact, However, a few hours in the sun should get you enough juice to help in case of emergencies, and when you're at home, just plug it into a wall and it'll be fully charged in about eight hours. Some reviewers say the power bank is a bit heavy, so you'll likely want to stash it in your daypack rather than in your pocket.
Shipping at Amazon is free on orders totaling $25 or more, but you could receive your order even faster with an Amazon Prime membership. If you've never been a member before, you can start a free 30-day trial to score free two-day shipping with no order minimum, along with access to the Prime Video streaming service, exclusive members-only discounts, and more.
