Reach 100% faster with Anker's slim 30W USB-C Wall Charger at a new low price of $22
As the company's slimmest USB-C charger so far, the Anker PowerPort Atom III 30W USB-C Charger is a perfect fit for plugging into power outlets hidden behind furniture or in hard-to-reach areas of your home. It's just over half an inch thick and charges devices super fast thanks to its USB-C port that supports Power Delivery. Though it's normally priced up to $35 at Amazon, right now you can pick one up on sale for just $21.99. That's the lowest we've ever seen it reach, and both the black and white models are on sale for this price.
Anker Soundcore Life Q30 hybrid active noise-cancelling Bluetooth headphones
$59.99 $79.99 Save $20
These hybrid Bluetooth headphones reduce ambient noise up to 95% thanks to active noise-cancelling mics. The battery lasts up to 40 hours with ANC on or 60 hours with it off, and recharge via USB-C. Clip the $20 on-page coupon.
Anker Powerline II 6-feet USB-C to Lightning cable
$12.74 $15.00 Save $2
When using a USB-C power adapter (not included), you'll get the fastest possible charge for your iPhone. Plus you can seamlessly sync and charge your Mac. This is Apple MFi certified and lasts 12 times longer than other cables.
Anker Liberty Air 2 Pro true wireless earbuds Best Buy
$79.99 $130.00 Save $50
These earbuds have active noise-cancelling that's customizable with a simple app. You'll get a total of 26 hours of playtime with seven hours from a single charge and the rest from the charging case. Uses USB-C and has wireless charging.
Anker Soundcore Rave Neo portable Bluetooth speaker with LED lights
$84.99 $120.00 Save $35
Includes a rechargeable battery that will last for up to 18 hours and can charge other devices with the USB port. IPX7 rated for water resistance. The built-in LED lights will sync to the music you're playing. Connect multiple speakers together.
Anker Soundcore Liberty 2 Pro true wireless earbuds black
$49.99 $100.00 Save $50
They last for up to eight hours on a single charge with up to 32 hours total using the charging case. They have quick charge so you can get two hours after 10 minutes spent charging. They also charge via USB-C or a Qi wireless charger.
This high-speed USB-C wall charger can power up a 12-inch MacBook from 0% to 100% in just two hours. It's universally compatible with USB-C devices and supports Apple and Samsung fast charging, as well as Qualcomm Quick Charge and USB-C Power Delivery. It doesn't come with a USB-C cable, so you'll want to make sure you have one handy when it arrives. However, Anker does include an 18-month warranty in case you experience any issues with its use. To keep it compact, Anker equipped this charger with a foldable plug and designed it to be 35% smaller than the comparable, yet much more expensive 30W Apple MacBook charger.
In need of a dependable USB-C cable to use with this charger? This guide to the best USB-C cables of 2020 can help you find one to add to your cart quickly. That should also help you reach Amazon's free shipping minimum so you can save a few dollars on this purchase if you're not currently a Prime member.
Shipping at Amazon is free on orders totaling $25 or more, or with an Amazon Prime membership. If you've never been a member before, you can start a free 30-day trial to score free two-day shipping with no order minimum, along with access to the Prime Video streaming service, exclusive members-only discounts, and more.
