The Razer Tartarus Pro is a gaming keypad that's $50 off right now
The Razer Tartarus Pro gaming keypad is down to $79.99 at Amazon. This is the lowest price ever on the Tartarus Pro, which regularly sells for around $130. It has only dropped from that price on Amazon once before when it went on sale for $100 earlier in January. Obviously that deal wasn't as good as this one, and once this price expires we might not see it drop this low for a while. You can get the same discount at Best Buy.
Razer Basilisk Ultimate wireless gaming mouse with RGB charging dock
$99.99 $140.00 Save $40
One of Razer's most comprehensive mice. Uses HyperSpeed tech so wireless feels as responsive as wired. Has a 20,000 DPI sensor with adjustable sensitivity. Customize the controls of the 11 buttons and the RGB lighting. 70-hour battery life.
Razer Viper Ultimate light wireless gaming mouse
$89.99 $110.00 Save $20
Has HyperSpeed wireless tech for extremely fast responsiveness that makes it feel like a wired mouse. Weighs only 74g so it moves easily. Has a 20,000 DPI sensor for precision that can be adjusted. Eight programmable buttons.
Razer DeathAdder v2 mini gaming mouse
$24.99 $50.00 Save $25
The grip tape gives you unprecedented control over the mouse even during fast-paced gaming. It also has an 8,500 DPI optical sensor with on-the-fly sensitivity adjustment. Use Razer Chroma for custom RGB lighting, too.
Razer Wolverine Tournament Edition gaming controller for PC and Xbox One
$79.99 $120.00 Save $40
Has a rapid-fire switch for instant actuation including a hair trigger mode to reduce the travel distance when pressing triggers. The four multi-function buttons can be remapped. Syncs with popular games and hardware including Razer gear.
Razer Opus active noise-cancelling Bluetooth headphones midnight blue
$149.99 $180.00 Save $30
The ANC in these headphones can detect and nullify incoming noise. They have a 25-hour battery life and are engineered for comfort that entire time with leatherette memory foam ear cushions and a well-balanced weight. Can go wired to save battery.
Put a series of 32 keys and an 8-way directional thumb pad at your fingertips for an instant response an enhanced control over your games, creative work, and more. The pressure-sensitive inputs and Razer analog optical switches can detect different levels of pressure and give you a much faster response as your fingers work to press different keys.
Every one of the keys and buttons is reprogrammable. That means you can set this keypad up perfectly for whatever you happen to be doing, and you can change the profile based on different activities. Every hotkey is at your command, and you can use Razer HyperShift to create complex actions, advanced macros, and an infinite number of keypress combinations.
The thumb pad gives you a more natural control over your system, especially if you are a console-oriented person who has been using joystick controllers. It's more ergonomic as well, so your wrists will thank you.
Last but not least, the Razer Chroma tech allows for customizable lighting on the pad. Not only do you get the full RGB spectrum of lights, but you can customize the effects as well. Work with third-party hardware like Philips Hue and other gear for a full lighting experience.
Be an expert in 5 minutes
