RAVPower's 10000mAh power bank on sale for $25 works with phones, tablets, and more
The RAVPower 10000mAh USB-C Power Delivery portable charger drops to $24.99 with code BJSFK4AJ on Amazon. That's $15 off its regular price and at least $9 better than any direct price drop we've seen. Any previous deal probably required a code, too, but it probably still didn't go nearly as low as this.
This isn't the only RAVPower device we've seen go on sale today, either. Need twice the power? Grab this 20000mAh battery charger for just $29.99, down from a street price around $50, when you use the code 3ILGNO96 and the on-page coupon.
RAVPower 65W 4-port USB Desktop Charging Station
$34.99 $49.99 Save $15
Keep USB ports close by with this 65W USB Desktop Charging Station by RAVPower. It's equipped with two USB-C ports as well as two USB-A ports. Clip the coupon on its product page and use the following code at checkout to save $15.
RAVPower 10000mAh portable charger dual USB power bank
$9.99 $15.00 Save $5
The ultra slim power bank is only 15mm deep, so it's extremely portable. The battery size of 10000mAh is enough for a full charge of even the largest phones. Can charge two devices at once and has built-in safety features to protect them all.
RAVPower 61W Power Delivery 3.0 USB-C 2-port wall charger
$23.39 $30.00 Save $7
Has 61W output with Power Delivery 3.0. Can charge a MacBook in 2.1 hours. Can detect what's plugged in and deliver fastest possible speeds. Wants to be portable with slim, compact design and foldable pins. Includes built-in safeguards.
RAVPower 48W USB-C Car Charger with Power Delivery 3.0 and Quick Charge 3.0
$14.99 $19.99 Save $5
RAVPower's fast dual-port car charger features a 30W Power Delivery 3.0 USB-C port along with an 18W Quick Charge 3.0 USB-A port. Clip its on-page coupon to snag this deal.
RAVPower 25000mAh solar phone charger outdoor portable charger
$21.99 $46.00 Save $24
Use sunlight to recharge this charger's batteries or plug it in via micro USB or USB-C. The 25000mAh capacity is enough to keep all your devices going outdoors. Includes an LED flashlight and SOS mode for emergencies. Waterproof and dust proof.
The 10000mAh RAVPower power bank has 29W total output. Use the two USB ports simultaneously to charge your devices, and the advanced power output means you won't sacrifice charging speed on either port to do it. The design is compact enough that you can take it with you, too, so you can keep it on you for whenever you need a quick top off.
A 10000mAh capacity battery is plenty of juice for just about any smartphone or tablet. You'll be able to charge an iPhone 11 or Samsung Galaxy S10 at least twice before needing to recharge the battery. That's enough power to keep you going throughout the day. Plus, the device comes with its own USB-C cable and can fully recharge in just three hours. You will want to get a USB-C wall adapter like this one from RAVPower for $16.99, to recharge the power bank.
The built-in safeguards help ensure your devices won't face any problems. Get protections from over-charging, over-heating, short-circuiting and more.
The gadget comes with a USB-C to USB-C cable, but if you want to charge something with a Lightning port you'll need to purchase that cable separately. Users give the charger 4.9 stars out of 5 based on 189 reviews.
