This RAVPower battery charger on sale for $65 includes an AC outlet for larger devices
The RAVPower 27,000mAh universal power bank with AC outlet is down to $64.99 at B&H. This is part of B&H's DealZone, which means it's a temporary one-day sale. The same power bank normally goes for $130, and it's still going for that price on Amazon. We've never seen this particlar power bank from RAVPower go for this low before, so grab it while you can.
RAVPower 65W 4-port USB Desktop Charging Station
$34.99 $49.99 Save $15
Keep USB ports close by with this 65W USB Desktop Charging Station by RAVPower. It's equipped with two USB-C ports as well as two USB-A ports. Clip the coupon on its product page and use the following code at checkout to save $15.
RAVPower 10000mAh portable charger dual USB power bank
$9.99 $15.00 Save $5
The ultra slim power bank is only 15mm deep, so it's extremely portable. The battery size of 10000mAh is enough for a full charge of even the largest phones. Can charge two devices at once and has built-in safety features to protect them all.
RAVPower 61W Power Delivery 3.0 USB-C 2-port wall charger
$23.39 $30.00 Save $7
Has 61W output with Power Delivery 3.0. Can charge a MacBook in 2.1 hours. Can detect what's plugged in and deliver fastest possible speeds. Wants to be portable with slim, compact design and foldable pins. Includes built-in safeguards.
RAVPower 48W USB-C Car Charger with Power Delivery 3.0 and Quick Charge 3.0
$14.99 $19.99 Save $5
RAVPower's fast dual-port car charger features a 30W Power Delivery 3.0 USB-C port along with an 18W Quick Charge 3.0 USB-A port. Clip its on-page coupon to snag this deal.
RAVPower 25000mAh solar phone charger outdoor portable charger
$21.99 $46.00 Save $24
Use sunlight to recharge this charger's batteries or plug it in via micro USB or USB-C. The 25000mAh capacity is enough to keep all your devices going outdoors. Includes an LED flashlight and SOS mode for emergencies. Waterproof and dust proof.
The RAVPower portable power bank has a huge battery capacity. The 27000mAh is enough to charge most mobile devices several times over. Since this battery charger has three USB ports and an AC outlet, that's plenty of juice for you to charge a whole bunch of things simultaneously.
The AC outlet on the side is perfect for giving some juice to your larger devices when you can't get near a wall outlet. Since it has a 100W output, it should work with everything from laptops to 110V blenders. The other ports include two USB-A and one USB-C, all of which can be used to charge any of your USB compatible devices. The USB-A ports have iSmart technology, which helps them determine what exactly has been plugged in and provide the best possible charge with up to 2.4A/5V for each port simultaneously.
Use the separate 1.6A/19 VDC input to recharge the power bank quickly. It also has eight built-in LEDs you can use to monitor the capacity of the battery so you know when to start recharging. Preserve the power longer by turning the power bank on or off when you want. Integrated air vents help keep the whole thing cool, even when you're piling on the devices you want to charge.
