Quickly power your phone with RAVPower's fast wireless charger on sale for $12
Ravpower Charger
Ravpower Charger (Image credit: Amazon)
The RAVPower fast wireless charger comes with a QUickCharge 3.0 wall adapter, and it's on sale for $12.24 when you clip the $6 off on-page coupon then use the code 89BRJJQE during checkout. Without these stacked discounts, the charger is selling for $23. The drop to $12 is one of the lowest we've ever seen. While we have seen discounts on this charger in the past, it has been a long time since we've seen the double discount.
RAVPower 65W 4-port USB Desktop Charging Station
$34.99 $49.99 Save $15
Keep USB ports close by with this 65W USB Desktop Charging Station by RAVPower. It's equipped with two USB-C ports as well as two USB-A ports. Clip the coupon on its product page and use the following code at checkout to save $15.
RAVPower 10000mAh portable charger dual USB power bank
$9.99 $15.00 Save $5
The ultra slim power bank is only 15mm deep, so it's extremely portable. The battery size of 10000mAh is enough for a full charge of even the largest phones. Can charge two devices at once and has built-in safety features to protect them all.
RAVPower 61W Power Delivery 3.0 USB-C 2-port wall charger
$23.39 $30.00 Save $7
Has 61W output with Power Delivery 3.0. Can charge a MacBook in 2.1 hours. Can detect what's plugged in and deliver fastest possible speeds. Wants to be portable with slim, compact design and foldable pins. Includes built-in safeguards.
RAVPower 48W USB-C Car Charger with Power Delivery 3.0 and Quick Charge 3.0
$14.99 $19.99 Save $5
RAVPower's fast dual-port car charger features a 30W Power Delivery 3.0 USB-C port along with an 18W Quick Charge 3.0 USB-A port. Clip its on-page coupon to snag this deal.
RAVPower 25000mAh solar phone charger outdoor portable charger
$21.99 $46.00 Save $24
Use sunlight to recharge this charger's batteries or plug it in via micro USB or USB-C. The 25000mAh capacity is enough to keep all your devices going outdoors. Includes an LED flashlight and SOS mode for emergencies. Waterproof and dust proof.
The wireless charging pad comes with a Quick Charge 3.0 wall adapter, which is perfect for ensuring you get the fastest charging speed possible, even if you're not using a Quick Charge phone. At least you know you're getting topped off as much as possible. A lot of times chargers require a separate purchase of a wall adapter, so you're getting a lot of value with this deal.
RAVPower's pad also has HyperAir tech, which helps deliver the fastest possible speeds for iOS or Android devices. You can get to full charge in just 30 minutes, which is exceptional. The pad is compatible with pretty much any Qi-enabled device, including the iPhone or Android phones. You'll get 10W output with Android phones and 7.5W with the iPhone. The Qi protocol even works with things like AirPods cases.
The device is case friendly and uses Power Wave to transmit through protective cases up to 8mm thick. The only things that might get in the way include foreign objects (like credit cards) or metal cases. The cooling silicone and aluminum alloy help disperse heat 20% faster, and the pad has built-in safeguards to prevent things like over-current, overcharging, and more. The actual design of the pad uses silicone for stability and grips on the base to keep it from slipping.
