PUBG: New State bugs, launch issues, and how to fix them on Android
PUBG: New State brings its battle royale players into the future, but even 2051 has its far share of bugs. Some things just never change. As is common with a multiplayer game like this, players have run into launch issues and bugs shortly after its release. These problems range from minor issues like abnormal colors to major ones like server disconnects.
PUBG Studios is working diligently on fixes for the community. In the meantime, we've compiled some of the most common issues that players are finding and the workarounds you can use to hopefully fix them and get to playing.
PUBG: New State — Known bugs and how to fix them
Server disconnects
Server disconnects are unfortunately common with multiplayer games like this, and there's not much that you can do. The developer is working to solve log-in issues and server errors due to a large influx of players. Until then, you may want to check your internet connection to make sure that the problem's not on your end.
📢Due to a large inflow of users in a short time period, some users may be temporarily experiencing log-in issues. We are looking into resolving this issue swiftly. Thank you for your patience.📢Due to a large inflow of users in a short time period, some users may be temporarily experiencing log-in issues. We are looking into resolving this issue swiftly. Thank you for your patience.— NEW STATE MOBILE (@PUBG_NEWSTATE) November 11, 2021November 11, 2021
Degraded graphics and flickering or abnormal colors
- Fix: Restart the app and don't launch the game from a friend invite link.
- Fix: Update your device's OS to the latest version and restart the game. Should that not fix the issue, change your settings to OPEN GL by going to Settings > Graphics > Graphics API and then restart the game.
Game does not start properly
If you have USB debugging enabled on your mobile device, you might want to turn that off while playing PUBG: New State. It's unclear what prompts this issue, but for whatever reason PUBG: New State does not play friendly with debugging turned on.
Be an expert in 5 minutes
- Fix: Disable USB debugging on your device.
- Fix: Update your OS to the latest version and relaunch the game.
Delay in showing NC and EXP
- Fix: The developer has temporarily disables the event icon while working on a fix.
📢 Known Issue: Delay in showing your accumulated NC and EXP. It is our Dev Team's priority to determine what is causing the delay. For a faster fix, we will temporarily disable the event icon. But, players are still able to match and play the game as usual.📢 Known Issue: Delay in showing your accumulated NC and EXP. It is our Dev Team's priority to determine what is causing the delay. For a faster fix, we will temporarily disable the event icon. But, players are still able to match and play the game as usual.— NEW STATE MOBILE (@PUBG_NEWSTATE) November 11, 2021November 11, 2021
Premium Pass Plus+ not able to be purchased
Players seem to be experiencing an issue where the Premium Pass+ cannot be purchased. This is a known issue that the development team is looking into, but there does not appear to be a quick workaround at the moment.
Control sensitivity not working correctly
- Fix: Reset the sensitivity to either Low, Medium, or High in the game's sensitivity settings tab.
Working on a fix
There's a full list of known issues over on PUBG: New State's website that the developer is working on. You can also view updates to some of these problems through the game's Twitter account., which is keeping tabs of the most pressing issues.
It may not be one of the best Android games at the moment, but hopefully with some time it will get there.
Jennifer Locke has been playing video games nearly her entire life. You can find her posting pictures of her dog and obsessing over PlayStation and Xbox, Star Wars, and other geeky things.
