Protect your home inside and out with up to 49% off YI security cameras
Yi is a company that strives to offer affordable security cameras for both inside and outside your home. There are different models to choose between based on your budget, and sometimes you can even snag a nice discount on one (or more, in this case). Right now, there are a couple of deals running at Amazon worth checking out with Yi home security camera kits with as much as 49% off.
Score a pair of 1080p HD cameras to keep an eye on your property with this one-day sale. The cameras feature a bunch of smarts like motion detection, night vision, two-way audio, Alexa support, and more. These are best-ever prices.
Yi 4K action camera and 3-axis gimbal stabilizer kit
$109.00 $199.00 Save $90
You can record up to 4K with 30fps or 1080p at 120fps. Capture 12MP photos. Use the electronic image stabilization tech and the gimbal to get perfect shots every time. Includes 360-degree omni-directional mics, Bluetooth, and high-speed Wi-Fi.
Four Yi 1080p W-Fi home security cameras
$89.00 $189.99 Save $101
$99.00 $189.99 Save $91
Yi's Outdoor Security Camera records in 1080p resolution and uses a 110-degree lens and universal ball mount to cover every direction around it. It's weather-resistant too, making it a suitable fit for both indoors and outdoors. You'll get motion-activated alerts and app notifications sent directly to your phone, and that feature works on both iOS and Android. You can use two-way audio to communicate through the camera, and it even features 12 infrared LEDs for night vision up to 50 feet. It comes with a free one-month trial to Yi Cloud, and supports microSD cards up to 32GB. This 2-pack of cameras is down to $71.99 which is the lowest we've ever seen for it.
The Yi Dome Camera 2-pack is also on sale, dropping to $55 in today's promotion. That's 39% off and a new low for the pair. They aren't weather-resistant and have quite a different look to them, but these would make a great pick to keep somewhere in your living room or elsewhere inside your home. Each camera records in 1080p and has a 345-degree horizontal and 115-degree vertical rotation range. Coupled with a 112-degree wide-angle lens, that means you can get full 360-degree coverage. These cameras can also lock on to moving objects when detected and pan to keep them in frame. Both cameras require a 2.4Ghz Wi-Fi connection which most modern routers and mesh networking systems like Eero support.
