Protect your home with $20 off Eufy's 1-camera home security system
Clip the on-page coupon to bring the Eufy Security eufyCam E wireless home security camera system down to $159.99 on Amazon. That's on top of an already pretty awesome discount to $180. The system usually sells for around $238 and was even going as high as $489 in early September. This is an all-new low for the 1-camera kit.
Eufy cordless stick vacuums and robot vacuum cleaners
As low as $140
Choose from a cordless stick vacuum or a robot vacuum. The cordless vac includes 120AW suction power for 8 minutes or 25 minutes in standard mode. Helpful for getting into tight spaces. The robot has 1300Pa suction and lasts up to 100 minutes.
Eufy Security Wi-Fi 2K resolution video doorbell
$119.99 $160.00 Save $40
You'll get a wireless chime you can use somewhere else in the house to hear the door wherever you are. Has a 2K resolution image with advanced HDR and distortion correction. Includes two-way audio, motion detection, and smart alerts.
Eufy RoboVac 15C Max Wi-Fi connected robot vacuum cleaner
$175.99 $ Save $
Comes with super strong 2000Pa suction so it can pick up even stubborn dirt. BoostIQ feature will even boost the suction when you need it. Lasts for up to 100 minutes. Use the EufyHome app and connect it to your smart home for more control.
Eufy Spaceview Security by Anker baby monitor camera bundle
$129.99 $170.00 Save $40
Has a large 5-inch 720p display for a sharp picture. Let's you see everything your little troublemaker is doing. Can pan 330-degrees and tilt 110-degrees so you can see the whole room. Get instant alerts. Has a range up to 1,000 feet.
Eufy Security SpaceView 720p video baby monitor with night vision
$109.99 $160.00 Save $50
Has a large 5-inch 720p display for a sharp picture. Let's you see everything your little troublemaker is doing. Includes a wide-angle lens for when your baby starts moving around more. Get instant alerts. Has a range up to 1,000 feet in open area.
This 100% wire-free camera system is IP65 weatherproof-rated and has an internal battery that can last for a full year on a single charge (or three years in standby mode). One of the biggest concerns with getting a wireless security camera is whether or not the battery's going to let you down when you need it most, but this one definitely won't. It films in 1080p resolution and features night vision as well so you can see anything going on outside no matter what time of day it is. And using the EufySecurity app, you'll be able to check in on the camera's video feed no matter where you are.
Unlike other security systems, the eufyCam E doesn't require that you pay for a monthly service to use it. A 16GB microSD card is included with its purchase so you can store up to a year of recordings without needing anything extra, but the home base supports up to 128GB so you can upgrade for more room if you want to. You'll also receive mounting hardware so you can install the camera easily around your home.
If you're looking to add more cameras to your setup, you can do that at any time in the future for $179.99 per camera. The packages above also include the required base station that helps the cameras all work together seamlessly, and it can support up to 16 total cameras and 34 sensors. The sensors are available for $39.99 apiece on Amazon.
