Poweramp for Android, the 2014 review
It isn't new, but Poweramp remains one of the very best music players around
Not too long back we compiled a list of what we thought to be the best 5 music player apps available on Android. Of the 5, one selected was Poweramp, a long time favorite of many a music fan. In fact, we first looked at Poweramp back in 2010. As time has passed Poweramp has been refined, seen new features arrive, but at its core what it is hasn't changed.
It's been a while since we looked at Poweramp in any great detail, so we've loaded it back up and given it a 2014 look over. Let's see if it's still one to beat.
The basics
So, Poweramp is a music player app, and a damn fine one at that. Enough? Of course not. It's a music player that offers so much more than most of the manufacturers own, stock music apps that ship with phones. Top of the list is that you get an equalizer and support for just about every audio format you could want, including FLAC.
Poweramp also has a pretty nifty customization thing going on with themes support. There's a whole host of third-party themes available to download through the Google Play Store to make it look as hot as you want it to. The current version offers you a choice of lock screen controls, too, including the standard Android ones or replacing them with its own lock screen.
Ease of use
Besides the features, the customizations, one thing Poweramp has in its favor is how easy it is to get to grips with. The music player has big album artwork, clear, easy to use controls and quick access to settings, albums, playlists and the equalizer.
Be an expert in 5 minutes
Finding all the music you have on your device is a straight forward process since Poweramp will scan it for you and at any point you can just hit the "Rescan" option to import new music or browse folders manually. You've got options to create playlists and create a queue to cue up what you want to listen to next.
The equalizer
With a good pair of headphones the equalizer can make a world of difference to the sound you're hearing. Split into two parts, you have the actual equalizer with presets, sliders, bass and treble controls and on a separate tab controls for tone and volume. If you're happy enough tweaking around yourself you'll be able to get it to your liking. Personally, opening up presets and turning it to "rock" every time does the business.
It's especially noticeable – or so I think – when you're playing FLAC files. The enhancement was worth turning it on for. But sound quality is highly subjective. The important thing is that Poweramp gives you every opportunity to get it just how you like it.
Themes, themes, themes
Theming Poweramp is as easy as going to the Google Play Store and finding one you like. Some are free, some are not. But there's plenty out there to choose from. That's not to say the stock player isn't nice enough looking, because it's not bad. But when you open it up to other creative souls to go nuts with you end up with some pretty special looking creations. What themes don't do – thankfully – is alter the basic operation of the app. So controls will remain where they should be, they just might look a little different.
Applying themes is easy, too. Under settings you go into "Look and feel" and hit theme. The developers have built a couple of different basic themes into the app, and they're OK. But the third-party themers out there have done a fantastic job creating some visual masterpieces for your music player. To get the best, you're definitely going to want to hit the Play Store.
Other cool features
The thing with Poweramp is that it's got so many individual little features that we could be here all day talking about them. So here's a quick list of some of the other awesome stuff it has to offer:
- If you like to chill out with some tunes before you hit the hay, Poweramps built in sleep timer will let you do that without having to worry about dozing off and leaving the music playing. Tell it how many minutes you want it to play for and settle in.
- If you like to sing along with your music Poweramp can interpret either lyrics tags in your music collection or search for them using the musiXmatch plugin.
- Edit the tags on your tracks from inside Poweramp
- Tell Poweramp to cut out the silence at the beginning and the end of tracks to give you better gapless playback
- Advanced tweaks are on hand to help with some issues you might be having, particularly with custom ROMs. For example if the audio stops when your screen goes off you can tell Poweramp to use Wakelock to keep it going.
- If you're into Last.fm scrobbling, you'll be fine.
The bottom line
The Android music player space has become much more crowded since Poweramp first made a splash back in 2010. We're blessed to have such a fantastic choice on offer, but Poweramp is still one of the absolute best around. It's got something for everyone. Whether you just want an easy to use, customizable music player or you want to tweak your sound and listen to lossless music.
If you rely on the cloud to keep your music stored, you might not be so suited to Poweramp. But if you take your collection with you, it still has to be one to try. And with a full featured trial period available, there really is no reason not to.
