With all the tech we've got to keep powered up these days, it's well worth having a charger for every situation. Whether you need a charge for your desk or nightstand, or a phone mount that lets you keep your phone juiced on the move, today is the perfect time to get yourself kitted out with iOttie's one-day sale.
The sale at Amazon has got you covered with deals on a variety of charging accessories. There is as much as 30% off its car mounts and Qi chargers there, but the deals expire tonight or when sold out.
iOttie iTap 2 magnetic CD slot car mount phone holder
$16.99 $25.00 Save $8
Uses your CD player's slot to mount the holder with two strong magnets that can handle any phone. The magnetic plates are easy to remove. Rotate on a ball joint for 360-degree viewing angles. Also has a dashboard pad and suction cup.
iOttie Easy One Touch 4 windshield and dashboard car mount
$19.95 $25.00 Save $5
Fits on your dashboard or windshield. Has an easy mechanism that just takes one touch to lock or release the phone. Includes a telescopic arm that can extend up to 6.5 inches and pivot 225 degrees so you can find the perfect viewing angle.
iOttie automatic clamping Qi wireless car charger dashboard phone mount
$41.95 $60.00 Save $18
The mount can automatically sense motion and opens or closes for a secure smartphone installation. It is Qi certified for wireless charging so you can keep juiced up even after a long road trip. Has a telescopic arm so you can get the perfect angle.
iOttie Tap 2 Wireless magnetic Qi wireless charging air vent mount and dual car charger
$37.30 $50.00 Save $13
Compatible with Qi wireless devices including iPhone and Android. Twist and lock for secure air vent connection. Comes with a dual USB car charger with one port for charging the mount and the other free to use. Uses rare Earth magnets to hold phones.
$20.23 $34.31 Save $14
The most affordable items in the sale are the phone mounts like the iOttie OneTouch 5 that let you secure your phone while driving in the right position so you can continue to use GPS navigation. These models don't have a charger built-in but they allow you to have your phone in a usable spot while you plug it into a cable and they start at just $17.
If you want to have your phone mount wirelessly charge your phone while it's in place, then iOttie's OneTouch Wireless 2 will do that for you from $36 or you can even add Alexa to your car with other options on sale.
For your home charging needs, check out the new iOttie iON Wireless Duo which is available at a 30% discount in a few different colorways. Now at $35, it earns its "duo" moniker from its combination of a wireless charging stand with a wireless charging pad making it the perfect addition to a nightstand where you need to power up your iPhone and AirPods overnight. Being Qi-certified, it also works with other wireless charging devices at up to 10W.
These deals are only available for a limited time, so be sure to get your orders in before prices rise again.
Be an expert in 5 minutes
