This power strip on sale for $25 works with your smart home
You are now subscribed
Your newsletter sign-up was successful
The Nooie smart power strip and surge protector is down to $24.99 on Amazon today. Just clip the $5 off on-page coupon and use the code XYIS9VFE to stack discounts and bring the total to 50% off its regular price. We've never seen this fancy power strip go this low.
The strip includes four AC outlets and four USB ports. The outlets are spaced nicely apart so you can use those larger power adapters. The strip includes overload and surge protection. It can absorb a large amount of sudden energy like during a power outage or storm and keep your electronics safe. The circuit breaker will automatically break off when it detects events like that.
You will want to connect the strip to your 2.4 GHz Wi-Fi network. From there you can download the free app that comes with it or connect it to your smart home. It works with both Amazon Alexa and Google Assistant so you can control whatever is plugged in with your voice. The plugs can even be controlled individually so it's not an all-or-nothing situation for the whole strip. Use the app to control them all remotely, turning them on or off even while you're away from home. Add lights, fans, heaters, and other appliances and then set specific times when they need to be used.
The 3.28 foot power cord uses heat resistant materials so it will last a long time and won't fray or wear down. You can also mount it to the wall or in any position you prefer. The strip comes with a two-year warranty and a lifetime of tech support.
Need a smart home device to pair with this smart power strip? We've got a couple deals going on that will score you one. Grab some Tile Bluetooth trackers with an Echo Dot for $70 or get one for just $9 with Amazon Music Unlimited.
