Power up anywhere with Anker's 15000mAh PowerCore Redux power bank at 15% off
Having a way to power up your phone while you're traveling or driving around town is important. The last thing you want to happen is for your device to lose power while you're trying to use it to find your way around, after all. Luckily, Anker's compact PowerCore 15000 Redux is on sale for just $32.39 at Amazon right now, saving you $6 off its regular cost of $38. Not only will you be snagging it at one of its best prices yet, but you'll also receive an 18-month warranty with its purchase just in case it experiences any issues.
Anker Soundcore Life Q30 hybrid active noise-cancelling Bluetooth headphones
$59.99 $79.99 Save $20
These hybrid Bluetooth headphones reduce ambient noise up to 95% thanks to active noise-cancelling mics. The battery lasts up to 40 hours with ANC on or 60 hours with it off, and recharge via USB-C. Clip the $20 on-page coupon.
Anker Powerline II 6-feet USB-C to Lightning cable
$12.74 $15.00 Save $2
When using a USB-C power adapter (not included), you'll get the fastest possible charge for your iPhone. Plus you can seamlessly sync and charge your Mac. This is Apple MFi certified and lasts 12 times longer than other cables.
Anker Liberty Air 2 Pro true wireless earbuds Best Buy
$79.99 $130.00 Save $50
These earbuds have active noise-cancelling that's customizable with a simple app. You'll get a total of 26 hours of playtime with seven hours from a single charge and the rest from the charging case. Uses USB-C and has wireless charging.
Anker Soundcore Rave Neo portable Bluetooth speaker with LED lights
$84.99 $120.00 Save $35
Includes a rechargeable battery that will last for up to 18 hours and can charge other devices with the USB port. IPX7 rated for water resistance. The built-in LED lights will sync to the music you're playing. Connect multiple speakers together.
Anker Soundcore Liberty 2 Pro true wireless earbuds black
$49.99 $100.00 Save $50
They last for up to eight hours on a single charge with up to 32 hours total using the charging case. They have quick charge so you can get two hours after 10 minutes spent charging. They also charge via USB-C or a Qi wireless charger.
The PowerCore 1500 Redux is capable of charging the latest iPhone and Samsung Galaxy devices several times before needing to be recharged itself. It has a 15000mAh capacity and utilizes PowerIQ and VoltageBoost to offer an optimized charge for each device so you don't overcharge anything. Plus, since it has two USB ports, you'll be able to power up two devices at the same time. Anker's Multipotent safety system works to provide protection for your devices while it's in use.
You may want to pick up a carrying case for your new power bank. Anker includes just a micro-USB cable with its purchase. At Amazon, 1,100 customers have left a review for the PowerCore 15000 Redux, resulting in a strong rating of 4.7 out of 5 stars.
For more ways to charge up with the PowerCore 15000 Redux, be sure to take a look at this guide to the best 3-in-1 USB cables which feature connectors for Lightning, micro-USB, and USB-C ports.
Shipping at Amazon is free on orders totaling $25 or more, or with an Amazon Prime membership. If you've never been a member before, you can start a free 30-day trial to score free two-day shipping with no order minimum, along with access to the Prime Video streaming service, exclusive members-only discounts, and more.
Be an expert in 5 minutes
