The Polk Audio Command sound bar on sale for $199 works with Alexa and Fire TV
The Polk Audio Command Alexa-enabled sound bar is down to $199 on Amazon. This deal is a match for its lowest price. It first dropped this low during Prime Day. Since then it has only gone to $199 a couple of times, and the last time it expired pretty quickly. The sound bar normally sells for around $300, and even when it does go on sale it usually just drops to around $250.
$199.00 $299.00 Save $100
$198.00 $299.00 Save $101
The sound bar is compatible with Dolby and DTS surround sound, which means you'll be getting a vibrant, immersive, home theater experience. With built-in Fire TV compatibility, you'll be able to access software like Amazon Music, Pandora, iHeartRadio, TuneIn, and more. It can also connect your Alexa-enabled smart home system for voice control of both the sound bar and the rest of your smart home. It works in multiple rooms and has automated over-the-air updates for new features. You can easily set it up with 4K compatible TVs thanks to dual HDMI 2.0a inputs and optical cables like these ones sold by AmazonBasics.
Vary your setup based on how you want it. Use the wireless subwoofer for room-filling bass. Adjust voice levels using Polk Audio's patented technology to get the clearest dialogue possible. Mount the audio system on a tabletop or on the wall using the keyhole slots.
Polk Audio has a ton of great systems worth looking into to improve your home audio experience. We have seen the MagniFi system, which includes a powerful sound bar, a wireless subwoofer, and two wireless speakers, go for as low as $400 in the past.
