Pick up Anker's compact 24W USB Power Strip while it's discounted to $16
For someone who never needs just one power outlet, Anker's USB Power Strip 2 could be the next essential accessory you add to your packing list. This compact power strip is fitted with two AC outlets and two USB charging ports so you can power up four devices simultaneously using just one wall outlet, and its USB ports even deliver an optimized charge based on what type of device is currently plugged in.
While the USB Power Strip 2 generally sells for $24 at Amazon, right now you can pick one up on sale for just $15.99. This $8 discount marks the best price it's ever reached and a deal you won't want to miss out on.
Anker Soundcore Life Q30 hybrid active noise-cancelling Bluetooth headphones
$59.99 $79.99 Save $20
These hybrid Bluetooth headphones reduce ambient noise up to 95% thanks to active noise-cancelling mics. The battery lasts up to 40 hours with ANC on or 60 hours with it off, and recharge via USB-C. Clip the $20 on-page coupon.
Anker Powerline II 6-feet USB-C to Lightning cable
$12.74 $15.00 Save $2
When using a USB-C power adapter (not included), you'll get the fastest possible charge for your iPhone. Plus you can seamlessly sync and charge your Mac. This is Apple MFi certified and lasts 12 times longer than other cables.
Anker Liberty Air 2 Pro true wireless earbuds Best Buy
$79.99 $130.00 Save $50
These earbuds have active noise-cancelling that's customizable with a simple app. You'll get a total of 26 hours of playtime with seven hours from a single charge and the rest from the charging case. Uses USB-C and has wireless charging.
Anker Soundcore Rave Neo portable Bluetooth speaker with LED lights
$84.99 $120.00 Save $35
Includes a rechargeable battery that will last for up to 18 hours and can charge other devices with the USB port. IPX7 rated for water resistance. The built-in LED lights will sync to the music you're playing. Connect multiple speakers together.
Anker Soundcore Liberty 2 Pro true wireless earbuds black
$49.99 $100.00 Save $50
They last for up to eight hours on a single charge with up to 32 hours total using the charging case. They have quick charge so you can get two hours after 10 minutes spent charging. They also charge via USB-C or a Qi wireless charger.
Anker's USB Power Strip 2 will be one tech accessory you won't want to travel without, as it allows you to turn one wall outlet into four ways to charge. You can leave your bulky USB wall adapters that take forever to power you up at home. These two high-powered USB charging ports have a max 24W output and provide an optimized charge based on the device that's plugged in, while the AC outlets have a max 1250W output. There's no surge protection included which makes this power strip a viable option to bring along on a cruise, too.
Its power plug is designed to be slim enough to plug in behind furniture and other tight spaces, and there's even a non-slip base so the power strip won't slide around on your furniture while it's in use. Anker included a few safety precautions including a thick, rubber-coated power cable, fire-retardant casing, and internal safety shutter which prevents random objects from being stuck into the outlet's holes. You'll also receive an 18-month warranty with its purchase.
Shipping at Amazon is free on orders totaling $25 or more, or with an Amazon Prime account. If you've never been a member before, you can start a free 30-day trial to score free two-day shipping with no order minimum. You'll also gain access to benefits such as the Prime Video streaming service, exclusive members-only discounts, and more.
