Pick up this 10W Aukey Wireless Charging Pad for only $10
One small change to your daily routine can make a huge positive difference. If you don't have a wireless charging pad yet, you should consider picking one up. Most modern phones are compatible with them, and you might even be able to use one to charge your headphones too. Basically, wireless charging is the future, and it's awesome. Setting your phone down to pick it up later with a replenished battery is about as convenient as it gets, plus you won't need to worry about bringing a phone charger around with you all the time once you have a wireless charger on your desk. They don't cost a ton of money, either. In fact, this Aukey 10W Wireless Charging Pad will cost you just $10.04 today when you apply coupon code CNJ5USX8 during checkout at Amazon. That's over 40% off the normal cost, and $10 is a small price to pay for something you'll use every single day.
Aukey 9-in-2 USB-C hub for MacBook Pro or MacBook Air
$41.99 $60.00 Save $18
Unique design requires two USB-C ports back-to-back, which is why this is particularly suited for a MacBook that has such a configuration. Turn those two ports into nine tools including HDMI, Thunderbolt 3, and a 100W Power Delivery charging port.
Aukey Sports true wireless earbuds with earhooks
$27.49 $50.00 Save $23
Include powerful 12mm drivers for high-fidelity audio. The ear hook design won't let go even when you're at the gym. They have IPX8 water resistance, which is full waterproof support. The battery life lasts up to 35 hours with the included case.
Aukey Bluetooth true wireless earbuds
Up to 30% off
All the prices are discounted and the costs vary between $21 and $49. All you have to decide is which one looks best to you and has the features you need (like the Sports earbuds that stay on even while you run). Choose from black, white, and pink.
Aukey KM-G6 LED Mechanical Gaming Keyboard
$27.99 $44.99 Save $17
This well-reviewed keyboard features 104 anti-ghosting keys, nine preset lighting effects, and even comes with a two-year warranty. Today's deal at Amazon saves you $12 off its regular price while supplies last!
$25.24 $50.00 Save $25
This highly-rated wireless charging pad can top your phone off at up to 10W. If your device isn't compatible with 10W charging, it'll be charged at either 7.5W or 5W. Note that your purchase doesn't include an AC adapter, and fast charging requires a special charger, so you might as well pick one up that can support it.
The charging pad is sleek and compact, with a textured charging surface to keep your phone safely in place. There are safeguards built-in to protect your device from overheating and overcharging as well. The charger is backed by a 45-day money-back guarantee as well as a two-year warranty.
Now that you have an easy way to charge your phone while sitting at your desk, what about on-the-go? This discounted power bank can help you out.
Louryn saves money on everything she buys (which is a lot.) In between waiting for Amazon deliveries, she pines for the next Elder Scrolls installment and checks Reddit for gaming rumors. She also loves Hearthstone, makeup, and beer. Find her on Twitter: @lourynstrampe
