What is Samsung Vision Booster?
A simple trick that makes Samsung displays look ultra bright.
Samsung employs a lot of specialized technologies for its Galaxy phones, but few shine as bright as Vision Booster. Beginning with the Galaxy S22 series, Samsung Vision Booster kicks in when a phone's display is in bright sunlight, making it easier to see when you're in the great outdoors.
But how does Vision Booster work and why is it different from a screen that's just very bright? Here's where you find out.
Samsung Vision Booster kicks in automatically when Adaptive Brightness is enabled in the phone's display settings and is present in all the best Samsung phones like the Galaxy S22 and Galaxy S23 lines. The Galaxy S22 Ultra and Galaxy S23 Ultra are the two phones that can get the brightest, peaking at 1,750 nits of brightness. The less expensive models often peak at 1,500 nits with Vision Booster.
But Vision Booster goes beyond just increasing brightness. In addition to maxing out those pixels, Vision Booster reduces contrast and changes up the tone mapping on the screen, producing an image that's technically less rich but more visible when viewing a screen under direct sunlight.
The important part here is to focus on being in direct sunlight which, at the normal contrast ratios and color depth levels, makes a display extremely difficult to view. That's because modern smartphone displays don't reflect light back into their pixels the way an E-ink device does. Rather, they have to produce enough brightness to overpower the Sun's rays from the perspective of our eyes.
In our Galaxy S22 Ultra deep dive review, Tshaka demonstrated just how much clearer the S22 Ultra's display can get in bright light with adaptive brightness enabled.
By lowering contrast and adjusting color tones and related color factors, Samsung can help reduce the contrast our eyes create when viewing a phone's display under bright sunlight. The result is a picture that's wonderfully bright even when using dark mode all the time.
Adjusting those other parameters also means that your battery won't drain as quickly when the phone needs to pump brightness up. That's because the image on the display is more effective in bright light, preventing the phone from having to max out the brightness just to make the panel visible.
The downside is that Samsung utilizes something called PWM dimming at all brightness levels to achieve the goal. Your Galaxy phone's display is rapidly turning on and off hundreds of times per second but is doing it so fast that most people's eyes can't see this flickering. Instead, what you'll see is a brighter or dimmer display depending on how long the display stays off during this cycle.
PWM dimming is handy from an engineering perspective but can cause health problems for people susceptible to light flicker sensitivity. Unfortunately, Samsung doesn't offer a way to turn off PWM dimming for people who might be negatively affected.
How to enable Vision Booster
Vision Booster is something that kicks in automatically when the phone's ambient light sensor detects bright sunlight, but it can't do that unless the "Adaptive Brightness" setting has been enabled. Here's how to do that:
- Unlock your phone and pull down the full quick toggles UI by sliding down on the status bar twice. The status bar is the bar at the top of your phone that displays the time, battery, and other icons.
- At the bottom of the screen, tap the three vertical dots located on the right side of the brightness slider.
- Slide the toggle for Adaptive Brightness to the right to enable the feature.
Now, any time you step foot in bright sunlight, Adaptive Brightness will utilize the Vision Booster function to make your screen more visible. Vision Booster only kicks in when super bright light is detected, so this isn't a feature that you can — or need — to use under darker conditions.
Phone deals: Best Buy | Walmart | Samsung | Amazon | Verizon | AT&T
Get the best of Samsung mobile with the Galaxy S23 Ultra. It's got the brightest and most detailed screen of any Galaxy device, a built-in S Pen, a processor that'll handle anything you throw at it, and 2-day battery life.
Be an expert in 5 minutes
