Nothing Phone 3a vs. Phone 2a: Setting the standard again
Phone 2a set the standard for midrange phones, and Phone 3a builds upon that foundation.
Something to see here
The Nothing Phone 3a is definitely something to consider if you're in the market for a midrange smartphone. It has a competent Snapdragon processor, a great triple-camera system, and a unique design. Plus, there's plenty of AI around Nothing OS, and it tends to be actually useful.
For
- Unique design and slim camera island
- Excellent triple-camera system with optical zoom
- Essential Key brings AI to your fingertips
- 3 years of OS upgrades and 6 years of security updates
- Mostly stock Android with optional Nothing tweaks
Against
- Essential Key is positioned awkwardly near the power button
- Gaming performance is worse than the Nothing Phone 2a
- Only available in U.S. via the beta program
- Many U.S. carriers and cellular bands are unsupported
Nailing the basics
The Nothing Phone 2a was the brand's first real attempt at a budget smartphone, and it got a lot of things right. With a capable processor and a flagship caliber display, the Phone 2a was a great option last year. However, it is getting older, and the newer Phone 3a beats it in many areas.
For
- 120Hz OLED display with slim bezels
- Faster gaming performance than the newer Phone 3a
- Glyph lighting for notifications and other software features
- Starts with Android 14, with three full Android OS upgrades
Against
- Not available in the U.S.
- Cheaper construction with a plastic back
- Doesn't include a charger
- Only a dual-camera system
As a smartphone startup in the 2020s, Nothing is trying to do the impossible by shaking up a huge established market, and it's starting with the midrange sector. Nothing's Phone 2a set the standard for what a midrange phone should be, and now the company is improving on that standard with the latest Nothing Phone 3a. It's only slightly more expensive than its predecessor, but offers a more complete package.
Neither phone is fully equipped for use in the U.S., as carrier support is limited and they are only sold via the Nothing Beta Program. However, both devices are ideal for regions like Europe and India. Starting at £329 or ₹24,999, the Nothing Phone 3a offers an excellent value proposition. But how does it compare to the Nothing Phone 2a? That's what we're going to find out in this comparison.
Nothing Phone 3a vs. Nothing Phone 2a: Design and display
Both the Nothing Phone 3a and Phone 2a have a striking design, and they look quite similar. The two smartphones have a "camera island" with rear sensors positioned in the top center of their back. Of course, the Phone 3a's bigger lenses and triple camera system make that camera island look gigantic compared to that of the dual-camera Phone 2a.
The newer model is slightly larger than its predecessor, with the Phone 3a packing a 6.77-inch screen and the Phone 2a featuring a 6.7-inch display. They use similar display technologies, with support for 120Hz refresh rates and an OLED panel. However, the Phone 3a has an LTPO screen, which will result in smoother animations. Both phones support HDR10+ and have a peak brightness rating of 1,300 nits.
The bigger and better theme of the Phone 3a makes it physically larger than the Phone 2a. It measures 163.52 x 77.5 x 8.35mm and weighs 201 grams, whereas the Phone 2a measures 161.7 x 76.3 x 8.6mm and weighs 190 grams. Like most 6.7-inch phones, the Phone 3a's size can feel like a burden at times, and you'll feel the weight. Overall, it's pretty similar to the Phone 2a in that regard.
Nothing also improved the durability of the Phone 3a, supporting IP64 for dust and water resistance. Oddly, the company switched from Gorilla Glass this year, using Panda Glass on the Phone 3a. The important part is that Panda Glass is hardened, so it ideally won't crack easily, but some reports indicate Panda is easier to scratch than Gorilla.
By comparison, the Nothing Phone 2a features an IP54 rating for dust and water resistance, and Gorilla Glass 5.
Nothing Phone 3a vs. Nothing Phone 2a: Performance and specs
Nothing made a big deal out of its switch from MediaTek to Qualcomm for its budget phones this year. The Nothing Phone 3a uses the Qualcomm Snapdragon 7s Gen 3, a budget chip recently optimized to improve AI performance. However, in benchmarks and real-world tests, we found that the Phone 3a is worse than the Phone 2a in gaming and graphics performance.
The MediaTek Dimensity 7200 Pro chipset in the Nothing Phone 2a seems to perform better in graphics tasks, while falling to the Phone 3a in CPU-based tasks. In our review, our own Nicholas Sutrich found that there was a 30-40% drop in benchmark FPS on the Phone 3a compared to the Phone 2a. This was reflected in real-world tests, too, even affecting relatively light games like Minecraft.
With that being said, both phones performed great in daily use. They can each be configured with 8GB or 12GB of RAM and either 128GB or 256GB of storage, but some configurations are only available in certain regions. In terms of battery, both phones have a 5,000mAh capacity. The Nothing Phone 3a charges slightly faster, with 50W support compared to the Phone 2a's 45W support.
Category | Nothing Phone 3a | Nothing Phone 2a |
Processor | Qualcomm Snapdragon 7s Gen 3 | MediaTek Dimensity 7200 Pro |
Display | 6.77-inch 120Hz LTPO OLED, 2392 x 1080, HDR10, 1300 nits HBM, 3000 nits max, 480Hz touch sampling rate, 1000Hz touch sampling rate in gaming mode, 2160Hz PWM dimming | 6.7-inch 120Hz AMOLED, 2412x1080, HDR10+, 1100 nits HBM mode, 1300 nits max |
Operating System | Nothing OS 3.1 (Android 15) | Nothing OS 2.5.4 (upgradeable) |
Memory | 8GB/12GB | 8GB/12GB |
Storage | 128GB/256GB | 128GB/256GB |
Rear cameras | 50MP f/1.88 Samsung, 1/1.57" sensor, 4K30, OIS, PDAF; 50MP f/2.0 Samsung, 1/2.74" sensor, 2x optical zoom, EIS, Autofocus; 8MP f/2.2 Sony, 120-degree FoV | 50MP f/1.9 Samsung GN9, OIS, 4K at 30fps; 50MP f/2.2 Samsung JN1, wide-angle |
Front camera | 32MP f/2.2 Samsung, 1/3.44" sensor | 32MP f/2.2 Sony IMX615 |
Battery | 5,000mAh | 5,000mAh |
Charging | 50W wired charging | 45W wired charging |
Connectivity | Wi-Fi 6, Bluetooth 5.4, global 5G bands, NFC, GPS, dual nano-SIM | 5G bands, Wi-Fi 6, Bluetooth 5.3, NFC |
Dimensions | 163.52 x 77.5 x 8.35mm | 161.7 x 76.3 x 8.6mm |
Weight | 201g | 190g |
Durability | IP64 | IP54 |
With the Phone 3a, Nothing is promising three full OS upgrades and six total years of security patches. It's starting with Nothing OS 3.1, which is based on Android 15 and includes all the latest AI features from Nothing, including the Essential Space. Although the Phone 2a got the Nothing OS 3 update, it won't get all the new AI features. Its last platform update will be Android 17, so it still has plenty of support left.
Nothing Phone 3a vs. Nothing Phone 2a: Cameras
For the first time, Nothing is offering a telephoto lens on the Nothing Phone 3a. For the regular Phone 3a, the 50MP f/2.0 Samsung telephoto camera only does 2x optical zoom, but it's better than nothing. The main camera is a 50MP f/1.88 Samsung sensor with a 1/1.57-inch sensor size, and it includes optical image stabilization. The third camera is an 8MP, f/2.2 Sony ultrawide camera with a 120-degree field of view.
Even without support for a high level of optical zoom, the telephoto lens in the Nothing Phone 3a helps it produce better zoom shots than its predecessor, as you can see in the image samples below.
The Nothing Phone 2a has a 50MP, f/1.9 Samsung GN9 main sensor that's very similar to the one on the Phone 3a. Notably, it still supports OIS and 4K30 video recording. That's paired with a 50MP, f/2.2 Samsung JN1 wide-angle lens with an 84.5-degree field of view.
On the front, both phones feature 32MP, f/2.2 cameras — more than good enough to snap all the selfies you need.
Nothing Phone 3a vs. Nothing Phone 2a: Which should you buy?
If you're in the market for a budget Android phone, the Nothing Phone 3a makes a compelling case. It's better than the cheapest Samsung Galaxy A series phones, and it's cheaper than the OnePlus 13R and the Google Pixel 8a — and the rumored Pixel 9a, for that matter. Due to the Nothing Phone 2a's limited availability, you won't find much of a discount on last-generation hardware. That's why the Phone 3a is our pick if you had to choose between it and the Phone 2a.
With that being said, the Phone 2a is still a worthy pick for a daily driver in 2025. The Phone 2a is still fast and runs the latest OS — it's even faster than the Phone 3a in graphics performance. For the Nothing Phone 2a owners out there, an upgrade to the Phone 3a isn't necessary.
The Nothing midranger to buy
The Nothing Phone 3a is a more appealing option for people in regions where it is fully supported, like Europe and India. In those places, the Phone 3a blows away the competition in terms of value. It has a great processor, an even better camera system, and delivers a polished experience.
Still kicking
The Nothing Phone 2a might not be the most appealing choice for people in the market for a mid-ranger in 2025. There are newer and better options available, like the Phone 3a. But with Android 15 and new features, the Nothing Phone 2a will still be a capable phone for years to come.
Be an expert in 5 minutes
Brady is a tech journalist for Android Central, with a focus on news, phones, tablets, audio, wearables, and software. He has spent the last three years reporting and commenting on all things related to consumer technology for various publications. Brady graduated from St. John's University with a bachelor's degree in journalism. His work has been published in XDA, Android Police, Tech Advisor, iMore, Screen Rant, and Android Headlines. When he isn't experimenting with the latest tech, you can find Brady running or watching Big East basketball.
