iPhone 15 vs. iPhone 15 Plus vs. iPhone 15 Pro vs. iPhone 15 Pro Max: Which should you buy?
iPhone 15 Pro colors
(Image credit: Apple)
The age of USB-C iPhones is here, with all models in the iPhone 15 series offering a USB-C charging port as standard. This is the biggest shift in iPhone charging tech in nearly a decade, with Apple moving away from the Lightning port for good.
iPhone 15 vs. iPhone 15 Plus vs. iPhone 15 Pro vs. iPhone 15 Pro Max: Design
iPhone 15 colors
A major change this year is the inclusion of Dynamic Island on all models; the smaller notch was limited to the iPhone 14 Pro portfolio last year, and it's heading to the iPhone 15 and iPhone 15 Plus this year alongside the Pro versions.
While the design hasn't changed too much, there are a few subtle changes. The sides are still flat, but there are contoured edges that should make the devices easier to hold and use. I'm not a fan of phones with flat sides, so I'm intrigued in using the iPhone 15 models and seeing if they're better in daily use. The iPhone 15 and 15 Plus are available in pink, yellow, green, blue, and black.
iPhone 15 Pro titanium
The iPhone 15 Pro and Pro Max are that much more interesting as they use a new titanium chassis that looks stunning.
And with the switch to titanium, the Pro models are lighter than last year's steel variants. This year's Pro models are available in black, gold, blue, and raw titanium. Another new addition that's limited to the Pro models it the Action Button; think of it a multifunction button that lets you launch a shortcut, start a timer, taking a photo, and so much more.
iPhone 15 vs. iPhone 15 Plus vs. iPhone 15 Pro vs. iPhone 15 Pro Max: Hardware
The iPhone 15 and 15 Plus are powered by the A16 Bionic, which debuted on the Pro series last year. The A16 Bionic delivers decent gains over the A15, but what makes a bigger difference is the efficiency gains. Both models get satellite connectivity as well, and the Emergency SOS feature.
A new feature that's debuting across the iPhone 15 portfolio this year is Roadside Assistance via satellite. The feature is similar to Emergency SOS, and uses the same satellite tech to deliver assistance when your car breaks down by the side of the road. It's rolling out in the U.S. this year, with more regions to follow soon.
The iPhone 15 Pro and Pro Max feature new silicon in the form of A17 Pro, built on a brand-new 3nm node — a huge win over Qualcomm, MediaTek, and Samsung Exynos. The 16-core neural engine is 2x faster, and you get a dedicated AV1 decoder this time.
The A17 Pro has 19 billion transistors and includes six cores, with a 10% increase in performance over the A16 Bionic. The GPU sees a fundamental shift this year, with the new 6-core part built on a new architecture and delivering 20% gains.
But what stands out the most is that the GPU now uses hardware-accelerated ray tracing — similar to the best NVIDIA cards. This new caliber of hardware allows games like Resident Evil Village to debut on iPhones, and I'm excited that Assassin's Creed Mirage — the next game in the series — is slated to hit iPhones at the end of the year.
Obviously, the biggest change is USB-C connectivity, and all models get the charging port as standard. The USB-C port works works with charging, audio, video, and data transfers, and the Pro models get a USB 3 controller with a 10 Gigabit bandwidth.
And when it comes to wireless, the 15W MagSafe standard is intact. Here's an overview of the hardware you're getting with the iPhone 15 portfolio:
Swipe to scroll horizontally
CategoryiPhone 15iPhone 15 PlusiPhone 15 ProiPhone 15 Pro Max
Display6.1-inch 60Hz OLED, Dynamic Island, 2556 x 1179, HDR10, 2,000 nits6.7-inch 60Hz OLED, Dynamic Island, 2796 x 1290, HDR10, 2,000 nits6.1-inch 120Hz OLED, Dynamic Island, 2556 x 1179, HDR10, 2,000 nits6.7-inch 120Hz OLED, Dynamic Island, 2796 x 1290, HDR10, 2,000 nits
ChipsetA16 Bionic, 4nmA16 Bionic, 4nmA17 Pro, 6‑core CPU, 6‑core GPU, 16‑core Neural Engine, 3nmA17 Pro, 6‑core CPU, 6‑core GPU, 16‑core Neural Engine, 3nm
OSiOS 17iOS 17iOS 17iOS 17
RAM6GB6GB6GB6GB
Storage128GB, 256GB, 512GB128GB, 256GB, 512GB128GB, 256GB, 512GB, 1TB256GB, 512GB, 1TB
Rear camera 148MP f/1.6, 26mm focal length, 4K at 60fps, 2x telephoto48MP f/1.6, 26mm focal length, 4K at 60fps, 2x telephoto48MP f/1.78, 24mm, 28mm and 35mm focal length, sensor-shift OIS, Dolby Vision 4K at 60fps, ProRes video, 2x telephoto48MP f/1.78, 24mm, 28mm and 35mm focal length, sensor-shift OIS, Dolby Vision 4K at 60fps, ProRes video, 2x telephoto
Rear camera 213MP f/2.4 wide-angle, 120-degree FoV13MP f/2.4 wide-angle, 120-degree FoV12MP f/2.2 wide-angle, 120-degree FoV12MP f/2.2 wide-angle, 120-degree FoV
Rear camera 312MP f/2.8 OIS, 77mm focal length, 3x optical zoom, 15x digital zoom12MP f/2.8 sensor-shift OIS, 120mm focal length, 5x optical zoom, 15x digital zoom
Front camera12MP f/1.9, autofocus, 4K at 60fps12MP f/1.9, autofocus, 4K at 60fps12MP f/1.9, autofocus, 4K at 60fps12MP f/1.9, autofocus, 4K at 60fps
Ingress protectionIP68 dust and water resistanceIP68 dust and water resistanceIP68 dust and water resistanceIP68 dust and water resistance
SecurityFace IDFace IDFace IDFace ID
Safety featuresEmergency SOS via satellite, Crash Detection, Roadside Assistance via satelliteEmergency SOS via satellite, Crash Detection, Roadside Assistance via satelliteEmergency SOS via satellite, Crash Detection, Roadside Assistance via satelliteEmergency SOS via satellite, Crash Detection, Roadside Assistance via satellite
ConnectivityGlobal 5G bands, Wi-Fi 6, Bluetooth 5.3, NFC, second-gen UWBGlobal 5G bands, Wi-Fi 6, Bluetooth 5.3, NFC, second-gen UWBGlobal 5G bands, Wi-Fi 6E, Bluetooth 5.3, NFC, second-gen UWB, Thread, USB3Global 5G bands, Wi-Fi 6E, Bluetooth 5.3, NFC, second-gen UWB, Thread, USB3
Charging20W over USB-C port, 15W MagSafe20W over USB-C port, 15W MagSafe20W over USB-C port, 15W MagSafe20W over USB-C port, 15W MagSafe
Dimensions147.6 x 71.6 x 7.8mm160.9 x 77.8 x 7.8mm146.6 x 70.6 x 8.25mm159.9 x 76.7 x 8.25mm
Weight171g201g187g221g
ColorsBlack, Blue, Green, Yellow, PinkBlack, Blue, Green, Yellow, PinkBlack Titanium, White Titanium, Blue Titanium, Natural TitaniumBlack Titanium, White Titanium, Blue Titanium, Natural Titanium
Price$799$899$999$1,199
iPhone 15 vs. iPhone 15 Plus vs. iPhone 15 Pro vs. iPhone 15 Pro Max: Cameras
iPhone 15 Pro side
The standard iPhones models are picking up a huge camera upgrade, and now come with a 48MP main camera as standard. There's also a 12MP wide-angle lens that's largely unchanged from last year, but the switch to a 48MP lens leads to sizeable gains in photos and videos from just about any situation.
The iPhone 15 Pro and Pro Max feature a larger 48MP camera this time around, and they use a new coating to reduce lens flare. What's intriguing is that the models get the ability to switch focal length between 24mm, 28mm, and 35mm. The 12MP wide-angle lens is similar to last year, and it doubles as a macro lens.
The 3x zoom lens on the Pro model has the same 77mm focal length as last year, and on the Pro Max variant, there is a new zoom lens that is able to deliver 5x optical zoom. The 120mm focal length is the largest on an iPhone, and the module uses OIS and 3D sensor shift to deliver stable photos and videos.
Portrait and Night modes are tweaked to take better advantage of the hardware, and Smart HDR should do a better job in outdoor conditions.
iPhone 15 colors
If you're looking to buy a new iPhone this year, the decision largely comes down to the screen size and camera tech. If you need a smaller device and don't want the best cameras that an iPhone has to offer, the iPhone 15 is the obvious choice. Coming in at $799, it is also the most affordable in the series, and the fact that it has the Dynamic Island and USB-C charging makes it an enticing option — you're basically getting a lot of the same hardware as the iPhone 14 Pro for a lot less.
Want a larger 48MP camera and the ability to shoot in Dolby Vision? You'll need to pick up the iPhone 15 Pro. You're paying $200 more than the standard model, and while you get the same screen size, it has a gorgeous new titanium chassis, the latest A17 Pro silicon, and the OLED panel goes up to 120Hz, making it that much more smooth in daily use.
And if you're interested in a large iPhone with great battery life, the iPhone 15 Plus ticks all the right boxes. It has the ideal blend of hardware, cameras, and battery longevity, and at $899, it poses a serious challenge to the best Android phones. The iPhone 15 and 15 Plus have trade-in offers of up to $600 in the U.S. when you turn in an iPhone 11 or older, and if you haven't made the switch last year, now is as good a time as any to pick up a new iPhone.
The iPhone 15 Pro Max is overkill for most users, but it has the best camera hardware — including that new 5x optical zoom lens — and delivers the best battery life. It is costlier this year at $1,199, but you get 256GB of storage as standard. So if you don't mind the premium and want all the latest features and terrific battery life, the iPhone 15 Pro Max is the way to go. Both Pro versions have trade-in offers of up to $1,000 starting today.
Harish Jonnalagadda
Senior Editor - Mobile
  • Bkdodger1
    If I go in I'm going with the iPhone 15 Pro Max in the titanium color... The price pretty much stayed the same since they dropped the lower GB storage...
    Reply
  • fuzzylumpkin
    Yeah, the entry level price stayed the same as long as you ignore the fact that it increased by $100 lol.
    Reply
  • Bkdodger1
    Yeah same price for 256GB for me I would not do 128GB haha
    Reply
  • cribble2k
    I'm buying none of the above mentioned products.
    Pixel 8 pro will be my next device.
    Reply
  • mustang7757
    I think I'm holding on to my iPhone 14 pro max for another Year unless they give me 1000 trade-in unlock version not through Carrier , as it stands they giving 650.00 no thanks
    Reply
  • Bkdodger1
    I checked the trade-ins through my carrier T-Mobile but it's not worth it.. they want me to go up on a higher plan which defeats the purpose of getting $1,000 off on the phone since I'll be paying more per month in the long run as usual smh lol
    Reply
  • mustang7757
    Yeah exactly
    Reply
  • Bkdodger1
    mustang7757 said:
    Yeah exactly
    This is why I always end up buying them out right.. Apple wants to give me $360 for the iPhone 12 Pro which is not worth it either
    Reply
  • mustang7757
    You can sell these iPhones privately for more
    Reply
  • Bkdodger1
    Oh most definitely Swappa....but thinking one more year with my iPhone 12 Pro
    Reply
