Got a Samsung Galaxy S24? Keep it fully protected with the TORRAS screen protector and Ostand case
A cracked screen or chipped casing is frustrating no matter what phone you have, but how would you feel if it happened to your brand new Samsung Galaxy S24? As one of the most expensive smartphones on the market, this phone is a big investment. So it’s a good idea to start planning how you’re going to keep it safe from the rough and tumble of life.
A big part of the S24’s appeal is its sleek form, so the TORRAS Ostand cases are designed to interfere as little as possible. They have a slim shell that packs some smart engineering and serious protection into a minimal case, adding only a thin layer to your phone’s slender design. Once inside, the S24 is protected from impacts equivalent to being dropped from up to 12 feet by shock-absorbing bumpers on the corners of the case.
The Ostand offers functionality as well as protection, and its most distinctive design feature is the O on its reverse side. Tucked flat into the back of the case when not in use, the O ring stays out of your way when you don’t need it. When you do, it gives you three options for holding, standing or mounting your phone.
First of all, it’s magnetic, so you can use it to stick your phone to any metal surface. Secondly, the ring moves through a span of 0 - 120 degrees, transforming the case into a stand that lets you position your phone at the perfect angle for watching videos or reading. If you’re a photographer, the stand will help you set stable shots that make the most of the S24’s 50MP telephoto lens.
The third function of the ring is to make holding your phone easier. The trend for larger phones means that the normal way your phone sits in your hand can put stress on your forearm, and it’s especially uncomfortable for those with smaller hands. Holding it by the ring is more comfortable because you can close your hand around it for a secure grip that makes it less likely you’ll drop your phone.
And the O ring’s sturdy hinge won’t let you down - TORRAS did some testing and found it was still good even after 30,000 uses.
TORRAS Diamond Shield Screen Protector
So that’s your phone’s casing taken care of, but what about the screen? Your main goal in using a cover might be to protect it, but TORRAS has gone further than that and developed a material that actually improves upon the existing surface. The Diamond Shield Screen Protector is made of tougher stuff than a built-in screen. It’s also less reflective, and a special coating repels both oil and water to reduce smudging. And unlike other screen protectors, it won’t impact color fidelity, so you can enjoy the S24’s vibrant display in all its glory.
Your first encounter with any screen protector is the installation process, and TORRAS has made sure their one is quick and easy to fit. It uses a special glue that eliminates bubbles to make this process even easier, and you can get it in place in just 15 seconds. Take a look at this video to see how easy it is:
In developing the Diamond Shield Screen Protector, TORRAS identified two screen properties that they wanted to improve upon: how it looks and how it feels.
A major factor affecting how much you enjoy looking at your screen is how reflective it is, especially if you use it outside a lot. Reducing reflections makes a big difference, so TORRAS has applied a special coating to their protector to reduce glare from ambient light, making it easier to view your screen outside - even in bright sunlight.
Unique glass tempering technology
Another consideration is that screen protectors can reduce display quality and change the colors that you see. Phone screens - and strong protectors, like this one - are made of tempered glass, which is also known as safety glass. It’s the same kind that’s used for car windows, shower doors and so on. Tempered glass has been treated with heat or chemicals to make it stronger than normal glass, but, unfortunately, this process affects how the material transmits light. Typically, light passing through tempered glass will be somewhat distorted and color fidelity will be affected.
To tackle this, TORRAS focused on the tempering process itself and developed a way to increase strength and hardness without disrupting light transmission and color fidelity. Not only that, the Tora-CRC strengthening process actually makes the glass three times harder than normal tempered glass. So your screen is protected, without diminishing what you see on it.
Making the screen super-smooth to the touch was another goal in creating this protector, and this has been achieved by developing a silky coating that repels water and oil. It helps to keep your screen clean and smudge-free, while also providing a more frictionless surface that makes your phone easier to use.
Your Samsung Galaxy S24 is in safe hands
Getting a phone like the S24 is an exciting moment that can be made even better by enhancing it with the Ostand case and the Diamond Shield Screen Protector. You can rest easy knowing that the Ostand guards against impacts, and your screen won’t get scratched or cracked. On top of that, your phone is easier to hold, has a built-in stand, and a less reflective, silky-smooth screen!
Be an expert in 5 minutes
