How fast is the Google Pixel 9 charging speed?
Battery life and Pixel 9 charging speed are slightly larger than the Pixel 8, which is a good thing.
What about the Pixel 9 Pro and 9 Pro XL?
Best answer: The Pixel 9 supports 27W fast wired charging, and the same applies to the Pixel 9 Pro, while the Pixel 9 Pro XL supports 37W charging. For wireless charging, the Pixel 9 charges up to 15W, the 9 Pro at 21W, and the 9 Pro XL at 23W when using the Pixel Stand (2nd Gen). All three phones support up to 12W wireless charging with standard Qi chargers.
Charge the Pixel 9 quickly by a cable or wirelessly
The Pixel 9, Pixel 9 Pro, and Pixel 9 Pro XL all promise more than a day's worth of battery life and even longer if you use the Extreme Battery Saver option. For fast charging, Google recommends using its in-house 45W fast charger. Even though all three phones support this same charger, the actual charging rates vary based on the model. The Pixel 9 and 9 Pro feature the same 4,700mAh battery capacity and can be charged up to 55% in 30 minutes.
The actual charging rate for both phones is 27W, with Google's 45W charger. The Pixel 9 Pro XL has a larger 5,060mAh battery, but Google claims its battery can charge up to 70% in 30 minutes. This is because the XL charges at 37W using the same adapter.
It's a similar story for fast wireless charging, too. Using the Google Pixel Stand (2nd Gen), the Pixel 9 can wirelessly charge up to 15W, while the Pixel 9 Pro can charge up to 21W, and the 9 Pro XL up to 23W. If you use your own Qi wireless charger, then all phones have a limited speed of up to 12W. The Pixel 9 series also supports reverse wireless charging through a feature called Battery Share, so you can charge other smaller devices like the new Pixel Buds Pro 2.
The Pixel 9 series are just some of the devices launched during the August 2024 Made by Google event. The event also introduced the new Pixel 9 Pro Fold, which Google claims will receive hours of charge in just minutes with the 45W charger, and the Pixel Watch 3, which also boasts faster charging speeds and a new larger 45mm model.
You can preorder the Pixel 9 series now, starting at $799 for the base Pixel 9 model.
Pixels for everyone!
Google's widest selection of Pixel phones yet, the Pixel 9 series has something for everyone. The batteries are slightly larger compared to the Pixel 8 series, but thankfully they can be charged just as quickly, either wired or wirelessly.
Roydon has been writing about personal technology for 10+ years, and has covered everything from news, reviews, features, to on-ground coverage of big trade shows like CES. He's passionate about mobile technology and computing, dabbles with photography, and is still struggling to work his way through his Steam and PS4 game library.
