Snapdragon 8 Elite for Galaxy SoC surfaces in new Galaxy S25 spec leak
Hands-on with the smaller Samsung Galaxy S24
  • An X tipster revealed a host of Galaxy S25 specifications, but the main highlight is the existence of a "Snapdragon 8 Elite for Galaxy."
  • The leak claims that all three flagship models will see this "overclocked" chip.
  • Whispers of an 8 Elite for Galaxy cropped up early in January after the S25 Ultra featured in a Geekbench 6 database listing.
  • The Galaxy S25 will debut on January 22.
Another Galaxy S25 series leak seemingly points us toward a souped-up version of a recent Qualcomm chipset.
The recent string of rumors stems from X tipster Arsène Lupin, who posted a set of three specification images concerning the entire Galaxy S25 series. The most important part of this leak is the supposed existence of a "Snapdragon 8 Elite for Galaxy" SoC. The rumor claims that this flagship chip variant is persistent across all three of the upcoming S25 phones.
This particular leak highlights the Galaxy S25 Ultra's 1TB variant, but it states it will receive 12GB of RAM with it.
It's a curious aspect of this leak, one that goes against what's previously been rumored for the phone.
Rumors of a Snapdragon 8 Elite for Galaxy cropped up at the top of 2025. The upcoming Ultra model was spotted moving through Geekbench 6 for its typical performance and clock speed tests. Interestingly, the database detailed that the chip the phone contained received lower scores than what's been tested in other 8 Elite-packed devices. However, what stood out was its clock speeds — those were a bit higher.
Per the listing, the S25 Ultra's speeds clocked in at 4.47GHz for two of its cores which normally have a speed of 4.32GHz. The rest of the chip's cores saw a speed of 3.53 GHz, which is in line with the recent chip's performance following launch.
The performance scores probably aren't something to sound the alarm over. Once again, the device in this Geekbench 6 listing had 12GB of RAM despite rumors claiming a 16GB version is possible. If true, it could mean that this overclocked Snapdragon 8 Elite for Galaxy will see higher overall scores/performance.
Also, it kind of makes sense for Samsung to chase another "for Galaxy" chip variant considering the Galaxy S24 had one.
In other news, the specifications leaked by X tipster Lupin today (January 17) double down on what recently surfaced. A major Galaxy S25 spec leak might've told us everything we need to know about the series, like the Ultra model's 6.9-inch, WQHD resolution display with a 120Hz refresh rate. The phone's cameras were also on deck, with rumors suggesting users might see a 200MP primary camera, a 50MP ultra-wide-angle lens, a 50MP periscope telephoto camera, and a 10MP telephoto lens.
The Galaxy S25 and S25 Plus will reportedly feature a 6.2-inch Full HD Plus display and a 6.7-inch WQHD resolution screen, respectively. The leak added that both phones will see the same triple camera array and boast a 50MP primary lens, a 12MP ultra-wide-angle camera, and a 10MP telephoto lens.
The Galaxy S25 series is preparing for a January 22 debut. To hold you over, check out our ultimate guide to the new phones.
Nickolas Diaz
News Writer
  • Stanley Kubrick
    But WHY? There are already reports of the new Elite SOC having an issue with overheating, and Samsung is NOT known for their cooling features. This new SOC is already way, way more than ANY cell phone could ever need/use so why overclock it at all? Will overclocking not just lead to too much heat and more battery use than necessary? Makes absolutely no sense whatsoever!
    Reply
  • mustang7757
    Yes I heard about the overheating on the snap dragon 8 Elite chip , but Samsung does have a pretty good cooling vapor chamber and the s25 is supposed to be 30-45 % better in this compared to last year's.
    Reply
  • Stanley Kubrick
    Well OK, that's good that they have adequate cooling... but it still begs the question... WHY?
    What advantage, other than bragging rights on bench marks, does overclocking bring to the daily function of the phone? The SOC's in use two, or three years ago were, and still are, overkill for 99.9% of anything being done on a cell phone! It's just change for change sake and "because" we can do it so we do it! SMH
    Reply
  • mustang7757
    I'm assuming over clocking can aid in some instances like demanding tasks but shouldn't be for everything you do on the device.
    Reply
