Best Samsung Galaxy Z Fold 4 car mounts 2025
Get the perfect travel accessory for your Galaxy Z Fold 4.
The best Galaxy Z Fold 4 car mounts allow you to make the most out of the premium foldable when you're out on the road. Easily among the most feature-laden Android phones in the market, the Samsung Galaxy Z Fold 4 can pull double duty as a tablet too. Its incredible 7.6-inch folding display is perfect for multi-tasking and can be used to view turn-by-turn directions, while simultaneously playing your favorite tunes.
That said, you need a proper car mount to securely hold the Samsung Galaxy Z Fold 4 as you're driving. Here are some of our favorite picks that can be fixed to one of your car's air vents, or even cup holders.
Check out some of the best Galaxy Z Fold 4 car mounts
Staff pick
Packed with goodness, DOODBI's wireless charger mount is a must-have accessory for your Samsung Galaxy Z Fold 4. It has a padded backplate that not only keeps the device from slipping off, but enables shock absorption too. The integrated dual coils have a 15W power output and keep your phone charged when it's in use. You also get an intelligent clamping mechanism with smart sensors for automatic charging.
Hassle-free usage
Spigen's smartphone accessories are regarded as some of the best in the business, and the One-Tap is no different. Made with premium polycarbonate, it features a super-simple mechanism for snapping in your Galaxy Z Fold 4 with little to no effort. The mount's hook design allows it to be securely attached to one of your car's air vents, and you can easily adjust the viewing angles in both orientations.
Keep it cool
Despite its compact design, TOPENKE's offering packs in a total of three coils that keep your Galaxy Z Fold 4 juiced up when it's in use. In addition, the wireless charger mount also comes with an integrated fan that automatically turns on if the phone gets a bit too hot while being charged. Its surface is made from high-quality glass, and you also get non-slippery silicone padding for improved protection.
Extreme flexibility
With JSAUX's universal cup holder mount, you can set up your Galaxy Z Fold 4 in your car exactly the way you want. The clamp is connected to the base via a metallic arm which has a wide height adjustment range. The three-part arm also features two flexible joints which allow you to position the phone at just about any angle. Its base can be sturdily fixed inside the cup holder, and you even get an Allen wrench included in the package.
Charge it up
When you're using your Galaxy Z Fold 4 in the car, it's important to ensure that it is properly juiced up at all times. That's exactly what JOYVEVA's offering does, thanks to its dual-coil design with a 15W power output. Specially designed for foldables and other large-screen devices, this wireless charger mount can not only be used in both portrait and landscape modes, but also charge the smartphone when it's folded.
Stable and sturdy
Designed to securely hold a heavy fold such as the Galaxy Fold 4, MAKAQI's wireless cup holder mount has an expandable base with non-slippery silicone extensions that make it fit snugly into your car's cup holder. The flexible arm easily lets you adjust the phone's viewing angles, while the dual-coil design ensures that the phone is charged in both folded and landscape modes, with a maximum 15W power output.
Make the Galaxy Z Fold 4 your perfect travel companion
It may no longer be the latest and greatest thing out there, but there's absolutely no denying that Samsung Galaxy Z Fold 4 is still one of the best foldable phones you can buy these days. Packing two gorgeous Dynamic AMOLED panels — one of which folds — it represents the best the world of Android has to offer. The foldable screen is great for multitasking, which makes the top-tier smartphone ideal for a lot of use cases, including when you're behind the wheel, as you can access your playlists and view turn-by-turn directions at the same time.
However, you need one of these best Galaxy Z Fold 4 car mounts to do that, and our top vote goes to DOODBI's wireless charger mount. Its padded backplate allows for better shock absorption, and the dual coils can wirelessly charge the phone at up to 15W. Then there's the Spigen One-Tap car mount, which can be fixed to one of your car's air vents and features a compact yet tough design We also like JSAUX's universal cup holder mount, which comes with a three-part flexible arm that lets you position the phone at any angle you want.
Although these car mounts work well, you can never be too careful with a phone as high-end as this one. Therefore, we suggest buying a good case before you start on your journey. The above-mentioned mounts should work with most cases, except for some exceptionally thick or rugged options.
Be an expert in 5 minutes
Christine Persaud has been writing about tech since long before the smartphone was even a "thing." When she isn't writing, she's working on her latest fitness program, binging a new TV series, tinkering with tech gadgets she's reviewing, or spending time with family and friends. A self-professed TV nerd, lover of red wine, and passionate home cook, she's immersed in tech in every facet of her life. Follow her at @christineTechCA.
