The fantastic Philips SHP9500 over-ear headphones have dropped to $70
The Philips SHP9500 HiFi precision stereo over-ear headphones are down to $70.14 on Amazon. These are interesting headphones because a few years ago you could find them for much cheaper, even as low as $50. But then Philips stopped making them so the price jumped into the hundreds. The headphones were so popular they got brought back and have been selling around $80 or more since then. The drop to $70 is the lowest they have been on Amazon since coming back.
Philips SmartSleep wake-up light
$79.95 $100.00 Save $20
Simulates the sunset and sunrise and includes 5 different wake-up sounds. Has an FM radio with snooze and automatic dimmable display. It also includes 10 brightness settings. Help establish a healthy sleeping and waking routine.
Philips Hue white & color BR30 starter kit
$69.99 $120.00 Save $50
The kit includes two multicolor BR30 smart bulbs and the Philips Hue bridge designed to help you unite your bulbs and connect them to your Wi-Fi network. Find the perfect lighting with preset scenes or lighting effects that sync to your movie.
Philips Audio Fidelio X2HR over-ear open-air headphones
Up to 20% off
The X2HR have Hi-Res Audio with 50mm high-def neodymium drivers and an acoustic open-back architecture. They have deluxe memory foam ear pads and a lightweight adjustable hammock with genuine leather.
Philips SmartSleep Connected sleep and wake-up light therapy lamp
$169.99 $200.00 Save $30
Built-in bedroom sensor and smartphone connection helps create ideal environment. AmbiTrack sensor measures your bedroom's temp, noise, light, and humidity. Customize the alarm, light, sound, and sunrise/sunset themes. Has clock and touch display.
Philips goLITE BLU Rechargeable Energy Light
$130.40 $137.79 Save $7
These headphones have 50mm neodymium drivers that deliver awesome sound and a 1.5 meter cable that gives you freedom to move around. The double-layered headband cushion and breathable ear cushion promise long-term comfort. They have an impedance of 32 ohm and a maximum power input of 200 Mw. You will love these headphones. They have very positive reviews with 4.5 stars based on 782 reviews.
