Rise and shine and save with the Philips Wake-Up Light on sale for $60
If you hate the sound of your morning alarm then you might want to snag this offer on the Philips Wake-Up Light alarm clock. It's down to $60 right now at Walmart. The same wake up light is $103 on Amazon. We saw it drop to $75 there a couple weeks ago, but it has never gone lower than that on Amazon.
Philips SmartSleep wake-up light
$79.95 $100.00 Save $20
Simulates the sunset and sunrise and includes 5 different wake-up sounds. Has an FM radio with snooze and automatic dimmable display. It also includes 10 brightness settings. Help establish a healthy sleeping and waking routine.
Philips Hue white & color BR30 starter kit
$69.99 $120.00 Save $50
The kit includes two multicolor BR30 smart bulbs and the Philips Hue bridge designed to help you unite your bulbs and connect them to your Wi-Fi network. Find the perfect lighting with preset scenes or lighting effects that sync to your movie.
Philips Audio Fidelio X2HR over-ear open-air headphones
Up to 20% off
The X2HR have Hi-Res Audio with 50mm high-def neodymium drivers and an acoustic open-back architecture. They have deluxe memory foam ear pads and a lightweight adjustable hammock with genuine leather.
Philips SmartSleep Connected sleep and wake-up light therapy lamp
$169.99 $200.00 Save $30
Built-in bedroom sensor and smartphone connection helps create ideal environment. AmbiTrack sensor measures your bedroom's temp, noise, light, and humidity. Customize the alarm, light, sound, and sunrise/sunset themes. Has clock and touch display.
Philips goLITE BLU Rechargeable Energy Light
$130.40 $137.79 Save $7
This light will help you wake up without feeling grumpy in the morning. It can simulate a sunset to help you relax and fall asleep. The colored sunrise simulation combined with a gentle alarm will get your day started off on the right foot. It's also great to use in the winter when the lack of natural light makes it extra difficult to wake up on the right side of the bed. And, with its built-in FM radio, you can set it to tune into your favorite station each morning to help you come around.
