Philips' best Hue LED light strip is over half off in this one-day deal
Philips Hue lights are some of the most versatile smart home lights on the market, with options ranging from standard light bulbs to light strips like the Philips Hue LightStrip Plus. These dimmable LED smart light strips can be controlled using an app on your phone and can change from over 16 million colors at your command. They're not the most inexpensive light strips out there, and you need a Hue Hub for them to work properly in your home, but thanks to a sale at Amazon offering over 50% off the regular cost, now's a better time than ever to make the purchase. At just $34.99, today's sale brings this product lower in price than it's ever been; it usually sells for up to $80 at Amazon.
Philips SmartSleep wake-up light
$79.95 $100.00 Save $20
Simulates the sunset and sunrise and includes 5 different wake-up sounds. Has an FM radio with snooze and automatic dimmable display. It also includes 10 brightness settings. Help establish a healthy sleeping and waking routine.
Philips Hue white & color BR30 starter kit
$69.99 $120.00 Save $50
The kit includes two multicolor BR30 smart bulbs and the Philips Hue bridge designed to help you unite your bulbs and connect them to your Wi-Fi network. Find the perfect lighting with preset scenes or lighting effects that sync to your movie.
Philips Audio Fidelio X2HR over-ear open-air headphones
Up to 20% off
The X2HR have Hi-Res Audio with 50mm high-def neodymium drivers and an acoustic open-back architecture. They have deluxe memory foam ear pads and a lightweight adjustable hammock with genuine leather.
Philips SmartSleep Connected sleep and wake-up light therapy lamp
$169.99 $200.00 Save $30
Built-in bedroom sensor and smartphone connection helps create ideal environment. AmbiTrack sensor measures your bedroom's temp, noise, light, and humidity. Customize the alarm, light, sound, and sunrise/sunset themes. Has clock and touch display.
Philips goLITE BLU Rechargeable Energy Light
$130.40 $137.79 Save $7
The Philips Hue LightStrip Plus is one of the best LED light strips on the market. Once you have it set up in your home, you'll be able to control it using a free app on various devices including smartphones and tablets. It even works with voice and smart home assistants like Amazon Alexa, Google Assistant, Apple HomeKit, SmartThings, and IFTTT so you can begin voice controlling the strip. Up to 50 Hue lights can be controlled simultaneously thanks to the Hue Hub, so the Lightstrip Plus can easily integrate with any Hue products you may already own.
The strip is flexible and 80 inches long, featuring an adhesive tape on the back that makes it easy to place this strip wherever you want it in your home. It can be trimmed to size too, or extended with the 40-inch Hue Lightstrip Extension. It's more than 25% off today as well. You could save on Philips Hue White and Color BR30 bulbs at Best Buy today, too.
To add even more affordable smarts to your home, take a look at our list of best smart home products under $100 once you're done checking out at Best Buy.
Adam Oram is a Senior Writer at iMore. He studied Media at Newcastle University and has been writing about technology since 2013. He previously worked as an Apple Genius and as a Deals Editor at Thrifter. His spare time is spent watching football (both kinds), playing Pokémon games, and eating vegan food. Follow him on Twitter at [@adamoram](https://twitter.com/adamoram).
