A parent's guide to buying a PS5
We're a year into the new console generation, but systems are still incredibly difficult to come by. This means that many will be getting ahold of the PS5 for the first time over the holidays. If you're unfamiliar with PlayStation or Xbox, the setup can be an intimidating process. And even if you know your way around a gaming console, there are still a few things you may want to know beforehand. We'll walk you through everything you'll need to know about buying a PS5, setting it up, and more.
Finding a PS5
The PS5 was released alongside the PS5 Digital Edition in November 2020, priced at $499 and $399, respectively. If you haven't been able to pick one up yet, be on the lookout at retailers like Amazon, Target, Walmart, Best Buy, and GameStop. Stock is coming and going in waves, so it'd be smart to sign up for email or text notifications at whichever website you're looking to buy from.
Setting up a PS5
Setting up a PS5 is fairly straightforward once you get it out of the box. We have a few guides to make it even easier on you:
- How to attach the PS5 base
- How to set up parental controls
- How to connect to Wi-Fi
- How to increase download speeds
- How to manage multiple accounts
- How to set up 2FA
- How to add your credit card
- How to update your PS5 system software
When it comes to physical space, you'll want to have a relatively large open area for the PS5 to fit. Its dimensions are 15.4 x 4.1 x 10.2 inches, so it's not exactly the smallest. Thankfully it can stand up vertically or lay on its side horizontally, so you have some room to work with. The PS5 shouldn't be wedged anywhere; it won't receive a decent airflow. I'd recommend having a couple of inches of space on either side of it and above when you place it on your entertainment center.
Transferring data to PS5
The PS5 will allow you to transfer your data over from PS4 with a Wi-Fi connection or external hard drive. Because PS5 games can only be played from the console's built-in SSD storage or another supported internal SSD, we recommend keeping your PS4 games on an external hard drive when playing them on PS5 that way, so they don't take up space. The PS5 has around 667.2GB of usable storage.
How to transfer PS4 games and save data to PS5
Why you should get PlayStation Plus
PlayStation Plus is a premium subscription service Sony offers with one-month, three-month, and 12-month memberships. Subscribers get access to online multiplayer, free games, cloud storage, exclusive deals, Game Help on PS5, the PlayStation Plus Collection, and a lot more.
Be an expert in 5 minutes
Game Help is a new feature for PlayStation Plus on PS5 that will allow them to access hints and guides for specific parts of games. The PlayStation Plus Collection is another new benefit coming to PS5 that grants members access to a library of PS4 titles for free.
Upgrading your PS5 storage
Sony designed the PS5 so that people can take off the side panels and swap out the SSD internally. Though this feature wasn't supported at launch, it was added in a firmware update. You can now use compatible SSDs to upgrade your storage, provided that they meet Sony's required specs. You will also be able to connect external hard drives using a USB cable, but these will only play PS4 games.
How to upgrade your PS5 storage with an SSD
Spec | Requirements |
Interface | PCIe Gen4 x4 M.2 NVMe SSD |
Capacity | 250GB – 4TB |
Cooling structure | Heatsink (single or double-sided) |
Sequential read speed | 5,500MB/s or faster |
Module width | 22mm width |
Form factor | M.2 type 2230, 2242, 2260, 2280 and 22110 |
Socket size | Socket 3 (Key M) |
Length | 30mm, 42mm, 60mm, 80mm, 110mm |
Height | Less than 11.25mm |
Total size w/cooling structure | Smaller than 110mm (L) x 25mm (W) x 11.25mm (H) |
What to do when the PlayStation Network is down
Just like when your internet goes out, the PlayStation Network can go down as well. When this happens, you probably won't be able to play any online multiplayer, access your digital games, or browse the online store. Usually, the situation is out of your hands, and you'll need to wait until Sony fixes it, but there are a few steps you can take to mitigate any potential problems.
On days like Christmas and the release of the PS5, the number of people trying to log in to their new consoles at once puts a strain on the system, and you may be unable to create or sign-in to your account. All you can do when this happens is wait it out.
Jennifer Locke has been playing video games nearly her entire life. You can find her posting pictures of her dog and obsessing over PlayStation and Xbox, Star Wars, and other geeky things.
