Panasonic's cordless body groomer and hair trimmer has dropped in price to $40
Body Trimmer
Body Trimmer
The Panasonic ER-GK60-S cordless body groomer and trimmer is down to $39.99 on Amazon after price matching one of Best Buy's deals of the day. The Panasonic trimmer dropped this low for Black Friday, but outside of that major event it has never gone this low before. It usually sells for around $60 at both retailers, although we have seen a couple drops to $50 recently. Still, with Valentine's Day around the corner it can't hurt to do a little yard work.
Panasonic eneloop BQ-CC55 power pack with 8 AA and 4 AAA batteries
$37.30 $50.00 Save $13
This is a 3-hour quick charger that can charge batteries individually or all at once. This bundle includes eight AA batteries and four AAA batteries and can charge both sizes. You'll get up to 2100 recharges. And the batteries can hold their charges.
Panasonic RP-HD805N-K over-ear noise-cancelling Bluetooth headphones
$79.99 $100.00 Save $20
Includes a built-in mic and multi-function button to help you take calls, adjust volume, activate a voice assistant, and more. Battery lasts up to 20 hours on a full charge and has Quick Charge. Has 3 levels of active noise cancelling.
PANASONIC LUMIX Waterproof Digital Camera Underwater Camcorder with Optical Image Stabilizer, Time Lapse, Torch Light and 220MB Built-In Memory - DMC-TS30K (Black)
$104.08 $179.99 Save $76
$103.44 $179.99 Save $77
Panasonic's trimmer is designed so you can use it on all the curves and countours of your body without irritating your skin. It uses gentle wide edge blades and the trimmer has hypoallergenic blades with rounded edges all designed with your comfort in mind. That way you can use this device to get hairs in areas like your underarms, chest, back, legs, groin, and other spots. The V-shaped head and sure grip handle help you control exactly what you're shaving and do it cleanly.
You'll get three attachments that help you adjust trimming lengths and the amount of precision you need. You can use the trimmer in the shower if you want, too, since it works either wet or dry. It's fully waterproof, which also means it's 100% washable so you can clean it easily.
Users give it 4.5 stars out of 5 based on 756 reviews.
