Forget the Pixel 6 Pro — the OnePlus 10 Pro design just leaked in full
- More detailed renders of the OnePlus 10 Pro have appeared.
- The new renders apparently give us a look at the "likely final version" of the OnePlus 10 Pro.
- It is expected to go on sale globally sometime in the first half of 2022.
After giving us a "first look" at the OnePlus 10 Pro last week, Onleaks and Zouton have teamed up once again to publish more renders and a 360-degree video showcasing the "likely final version" of the upcoming OnePlus flagship.
The renders suggest the OnePlus 10 Pro will look fairly similar to the OnePlus 9 Pro from the front. It will have a curved screen with a single hole-punch cutout in the top-left corner. On the back of the phone will be a large rectangular camera bump housing a total of three sensors.
The phone also appears to have a rounded bottom and a flat top. While the phone's right side has an alert slider and the power button, the volume control buttons are on the left.
Unfortunately, the key specs of the OnePlus 10 are yet to be fully revealed. Rumors suggest OnePlus' next flagship will feature a 6.7-inch display with a tall 20:9 aspect ratio and a 120Hz refresh rate.
The 2022 flagship is also expected to be the company's first phone to support 125W wired charging. Several other flagship devices from OnePlus' sister brands OPPO and Realme are rumored to support 125W charging as well. OnePlus' current best Android phones top out at 65W.
The OnePlus 10 Pro will likely be launched sometime in early 2022, alongside the vanilla OnePlus 10.
OnePlus 9 Pro
Be an expert in 5 minutes
The OnePlus 9 Pro is one of the most impressive Android flagships launched this year, offering brilliant performance and fantastic camera performance. It also has an ultra-smooth 120Hz AMOLED screen and supports 65W wired charging.
