On now: get $50 off the Roborock S5 Max
Roborock S5 Max
Roborock S5 Max (Image credit: Roborock)
You've got a busy life. It isn't easy juggling a career with pets, kids, or both. Particularly a successful one.
After a long day at work, the last thing you want to do is clean. You want to sit down, kick back, and relax. But you need to make sure your house is tidy, especially your floors and carpets.
They're usually the worst offenders, after all. They somehow manage to attract more dust, dirt, and grime than any other surface in your home. And ignoring that mess isn't an option, especially if you have pets.
Roborock S5 Max
Source: Roborock (Image credit: Source: Roborock)
Here's where Roborock comes in. They've been a big name in the automated vacuum space for a while, quickly emerging as an incredible competitor to established brands. Their latest release, the Roborock S5 Max, is their best yet.
Equipped with a 290ml electric water tank and 2000pa suction with automatic carpet boost, it's able to mop and vacuum up pretty much any mess you can imagine. From within the Roborock app, the S5 Max provides you with an incredible level of control. You're able to easily dictate precisely where, when, and how it'll clean, right down to the water flow for its mopping functionality and the suction strength on its vacuum.
Roborock S5 Max
The S5 Max is also ideal for large homes, with up to 150 minutes of continuous cleaning time. Unlike some other robotic vacuums, which require the purchase of additional peripherals, it also lets you virtually set up no-go and no-mop zones from within the companion app. Moreover, once it's learned the layout of your house, you can configure it for room-specific jobs, allowing you to deploy it as-needed to pick up messes and spills.
In short, it's simple, powerful, and efficient — everything you could possibly need in a piece of smart technology.
If you purchase yours before the end of the month, you'll get $50 off! More details about the product and the promotion can be found below.
