The new Nexus 7: Wireless charging feature
If you were one of the lucky ones who was already able to score a new 2013 Nexus 7, you might not know about a great feature -- Qi wireless charging. It doesn't charge your new tablet fast, and it still requires a cord be plugged into the wall, but it is a great feature for the nightstand or your desk. While the tablet is sitting there not being used to play games, surf the web, or browse your favorite social media network -- all things it does very, very well -- it can be collecting a few charged electrons to keep the battery bumped up. And it makes a great nightstand clock with the Dashclock extension and Daydream feature activated.
We've got a handful of Qi chargers laying around, so I've been fiddling with them all morning. I want to see which ones work the best out of the bunch, and fans of the Nexus brand will be pleased with the result -- the Nexus Charging orb is a perfect match for your new Nexus 7.
They all work. Nokia's charger seems to work fine on my tablet, but offers no compelling reason to choose it over any others. The big Energizer Qi charging mat works fine, too, but it's ugly as sin and life is too short for ugly accessories. The LG puck works really well, and the fact that the charging coil is mounted directly in the center of the back cover of the Nexus 7 makes it easy to place and it stays put. But that blinking light will drive you bonkers at night.
Enter the Nexus charging orb. You new tablet grips the funky rubber surface of the orb just fine and won't slip, and the angle it keeps your Nexus 7 resting at makes that big, beautiful screen easily viewable while it's charging. Combined with some of the great Daydreams available in Google Play, it's the perfect solution. And it's powered by holo. Ok, not really, but it does say NEXUS on the face of it.
If you've got a Qi charger laying around, by all means use that one with your Nexus 7. If you have to buy one, because come on, you have to, grab the Nexus Orb from Google Play. You can use the link above. There are a couple pics after the break, and plenty of room for all your comments.
Be an expert in 5 minutes
