Upgrade your Wi-Fi with the Nighthawk X4S smart router on sale for $172
The Netgear Nighthawk X4S R7800 smart Wi-Fi router is down to $171.90 on Amazon. The router fluctuates a lot in price, but this drop is one of the lowest we've seen all year. The router more regularly sells for $200 and sometimes goes as high as $230.
Netgear CM1000 DOCSIS 3.1 cable modem
$129.99 $170.00 Save $40
Compatible with Comcast, Spectrum, Cox and most cable providers. Has DOCSIS 3.1 and supports up to 1 Gigabit internet speeds. Can work with any Wi-Fi router as well. Rental fees can cost up to $170 per year, so it pays for itself.
Netgear AX1800 Wi-Fi 6 4-stream wireless router
$66.21 $90.00 Save $24
Can handle speeds up to 1.8Gbps over wireless and works with Wi-Fi 6 devices like the iPhone 11 or Galaxy S10. Use the Nighthawk app for easy setup and management, including testing your internet speed and data usage.
Netgear Nighthawk MK62 AX1800 whole mesh Wi-Fi 6 system router and extender
$167.12 $200.00 Save $33
Includes one router and one satellite extender to cover up to 3,000 square feet in Wi-Fi. Get four powerful streams with speeds up to 1.8Gbps and reliable performance for more than 25 devices with MU-MIMO Smart Connect. Includes Ethernet ports.
$374.09 $499.99 Save $126
Netgear 16-port Gigabit Ethernet unmanaged switch
$156.06 $189.99 Save $34
The Nighthawk covers up to 2,500 square feet in wireless coverage. It has speeds of AC2600 on dual-band Wi-Fi, which means 800 Mbps on 2.4 GHz and up to 1733 Mbps on 5 GHz. You can connect up to 45 devices at once and still get reliable coverage for streaming videos, playing games, and more. There are four Gigabit Ethernet ports where you can plug in for a more stable experience. The advanced features include four amplified antennas, Beaforming+ tech, MU-MIMO tech, and more. The router can even connect to Amazon Alexa, so you can use voice control to give out guest passwords and things like that.
