Put your vehicle's CD player to use with this discounted phone mount for $6
A phone mount is one of the most essential, yet affordable purchases you can make for your vehicle. Whether you use navigation apps to help you find your way or live in a state where cellphone use is banned while driving, having a phone mount in your car can be a major help. Today at Amazon, you can snag Mpow's CD Slot Car Phone Holder for just $5.99 when you first clip the coupon on its product page and then enter promo code UWK6NTIK during checkout. That'll save you nearly $7 and bring this mount lower than it's ever reached without a code before.
This phone mount puts your vehicle's dusty CD player to use and has a piece which slides into the CD slot to make sure it remains steady during your drives. A button allows you to quickly mount or remove your phone, and it even features a ball joint which allows you to rotate it 360 degrees so you can view your device in either landscape or portrait mode.
More than 16,500 customers have left reviews for this phone mount at Amazon, resulting in a solid rating of 4.4 out of 5 stars.
Another smart way to keep your hands off your phone while driving is with this AUKEY Bluetooth Receiver which lets you add Bluetooth to any vehicle by utilizing its AUX input. Using the coupon on its product page will drop its price to $18.99 and save you $5 for a limited time.
