Add a phone mount to your vehicle with Mpow's two-pack on sale for $10
Driving around without your phone in a mount causes more problems than it's worth. You can more easily navigate with your GPS app while ensuring cops don't think you're texting while driving, and they're pretty affordable too. Save yourself some trouble, and some cash, with this two-pack of Mpow Car Phone Mounts by using code MPOWK140 during checkout at Amazon. That'll drop the pair's cost to just $9.99, saving you $5 in the process.
Mpow X5 hybrid active noise-cancelling true wireless earbuds
$39.99 $60.00 Save $20
The hybrid active noise-cancellation on these earbuds uses an outward-facing mic to capture the bad noises and an inward mic to monitor the sound reaching your ears, then uses anti-noise to cancel out the bad stuff. Has 32-hour battery with the case.
Mpow MS1 in-Ear Bluetooth Earphones
$16.99 $29.99 Save $13
These true wireless earbuds come with a charging case that keeps them playing for up to 25 hours while you're on the go. There's also a built-in microphone and IPX7 waterproof nano-coating to keep them protected from runs in the rain and splashes.
Mpow H5 Active Noise Cancelling Over-Ear Bluetooth Headphones
$29.99 $49.99 Save $20
$33.73 $52.99 Save $19
$33.73 $53.99 Save $20
These phone mounts are compatible with most smartphones and clip onto your vehicle's air vent to ensure your device stays steady for the ride. The air vent clip is adjustable so you can get it to fit on most car air vents whether they're thin or thick with vertical or horizontal blades. The mounts even allow you to rotate your device 360 degrees so you can use it in either portrait or landscape mode. Mpow includes a 2-year warranty with today's purchase.
Since you'll be keeping your hands off your phone from now on, you might also benefit from picking up a Bluetooth adapter so you can add Bluetooth functionality to any vehicle and start taking calls hands-free. You can snag one for just $13 today too.
