Monoprice's 27-inch 1440p 144Hz gaming monitor has dropped to just $250
The Monoprice MP 27-inch Zero-G 1440p 144Hz gaming monitor is down to $249.99 through the Monoprice website and comes with free shipping. That's important because Monoprice products tend to be great but not on sale because of high shipping costs. The same monitor sells for $320 or more at other retailers like Walmart even though it's still coming through Monoprice as a third party. And that's generally because Monoprice incorporates shipping into that cost.
Dark Matter by Monoprice Collider Cherry MX Red mechanical gaming keyboard
$57.12 $90.00 Save $33
This is a Monoprice brand that includes Cherry MX Red mechanical switches. Get that tactile feedback and click-clack of a mechanical keyboard at an affordable price. Built on steel for durability. Has per-key RGB lighting and programmable macros.
Monoprice SonicSolace active noise-cancelling Bluetooth over-ear headphones
$24.99 $60.00 Save $35
Up to 8 hours of play with active noise-cancelling and Bluetooth enabled. Double that without ANC. Has powerful 40mm drivers with neodymium magnets and a 20Hz - 20kHz frequency response. Uses Bluetooth 4.0 for easy pairing and low power consumption.
Monoprice Obsidian Speed Plus 5-port 80W USB-C desktop charger
$34.70 $48.00 Save $13
Get one 80W Power Delivery USB-C port and 4 USB-A ports outfitted with Quick Charge 3.0 so no matter what you plug in, you're getting a super fast charge every time. Use the included stand to orient the charger vertically if you wish.
Monoprice Obsidian Speed 85W Power Delivery USB-C wall charger
$13.00 $45.00 Save $32
Comes with free shipping although there is a warning about delays caused by COVID-19. With 85W power this could easily charge a laptop or any other USB-C device. Includes foldable plug and compact size for easy travel. One year warranty.
$199.99 $250.00 Save $50
Use the mobile app and Wi-Fi to start your prints easily. Has full auto leveling so you don't need to do manual adjustments. Comes fully assembled with step-by-step installation guide. Compact enough for a desktop or even dorm room.
This deal is coming around because Monoprice has discontinued this model. That's ok because it just means a fabulous screen becomes even more affordable, until this deal expires and then we never see it again. Monoprice's displays are notorious for sacrificing build quality for the sake of amazing image quality. The stand isn't nearly as important as the pixels, though, so just look past that. Plus, it's VESA compatible so you can just mount it and forget about the stand altogether.
You'll get 1440p pixel resolution with a 144 Hz refresh rate, a 1 ms response time, and AMD's FreeSync tech to reduce screen tearing. Even though it's a TN panel, it still has decent viewing angles up to 176 degrees. The connectivity options include three HDMI ports and a DisplayPort.
Be an expert in 5 minutes
