Watch live TV for free with Mohu's Leaf Metro HDTV antenna on sale for $13
Ditching your cable subscription these days is more enticing than ever. With major streaming services like Disney+ and Apple TV+ debuting in just a few short months, now's the time to cut the cord and switch to streaming for good! Along with finding the right streaming device for you, whether that's something like the Roku Streaming Stick+ or the Apple TV, your next step is to pick up an HDTV antenna so you can watch live TV channels in your area without having to pay a monthly bill. One great option is the Mohu Leaf Metro 25-mile HDTV antenna that's on sale for just $12.99 at Amazon today only. This is a stellar low price for an antenna that more regularly sells for around $18 there, and a price-match of a one-day sale at Best Buy where it regularly sells for up to $20.
Mohu Curve 50 indoor amplified 50-mile TV antenna
$35.00 $59.95 Save $25
Mohu Leaf 50 Indoor HDTV Antenna, Amplified, 60 Mile Range, Original Paper-Thin, Reversible, Paintable, 4K-Ready, 16 Foot Detachable Cable, Premium Materials for Performance, USA Made, MH-110599
$34.55 $59.95 Save $25
$41.97 $59.95 Save $18
$41.90 $59.95 Save $18
When this thing calls itself "Metro," it means it. The 25-mile range is really short for an HDTV antenna, so you'll want to make sure you live in an urban area if you use it. Use a reception map like this if you are unsure about how strong the signal might be in your area. You can use the antenna to access high def over-the-air TV channels even when you don't have a cable subscription. What exactly is available to you will be based on where you live, but you could receive channels like ABC, NBC, PBS, Fox, and more.
The Metro's design is much smaller than other HDTV antennas, which means it will blend in a lot nicer. It's multi-directional and reversible so you can place it just about anywhere. Plus, you can paint it if you want it to match the color of the room it's in. The ten-foot high-performance cable gives you a lot of flexibility for placement, too.
Don't live in a metro area and need some more range? This 1byone 80-mile HDTV antenna is on sale as low as $25 for Amazon Prime members. If you're not a member yet, you can start a free 30-day trial to score the extra few dollars in savings.
