Minus has rolled out its latest release for Android users, bumping the app up to v3.0.17. If you're currently using Minus on your device for your file sharing needs you'll want to make sure you grab this update as it brings some much needed changes:
- Basic searching for users/folders
- Upload multiple files at once with new built-in picker
- Upload faster and more stable than before
- User profile added, with folder lists and avatars
- Copy Link button returns, now with options!
- Updated Image Editor to use new Aviary Feather 2.0
- Invite and follow friends on Minus for Android
- View all of your folders, and all files in a folder
- Context Menu in Folder View
- Clearer error messages
- View captions and other file info
- SSL connections added for more security
- Many other stability and bug fixes
As a reminder, Minus will give you to 50Gb in storage for your hosting needs and files as large as 2GB can be uploaded to your account, although you'll likely want to use their desktop solutions if you're moving that much content. The updated release can be found past the break for you all.
Be an expert in 5 minutes
LATEST ARTICLES
