Meross smart products including plugs, garage door remotes, and more are up to 40% off today
Today is your day to put the finishing touches on your smart home. You can save up to 40% off Meross smart home products including the famous Meross smart garage door opener, a 4-pack of smart plugs, outdoor plugs with weather resistance, and more! All of these items are being sold by Woot through Amazon, and that's expected because the last couple of times we've seen a big Meross sale it was through the Woot website in the first place. This just eliminates the middleman, gives you Prime delivery, and makes the savings super easy to see.
Grab the Meross smart garage door remote for less than $31 and control your garage door from your phone or with your voice. Other options on sale include 4 smart plugs for just $23, outdoor plugs that are weather resistant, light switches, and more!
Meross dual outlet smart plug 2-pack
$25.99 $34.00 Save $8
Create two outlets with one plug and a compact design that won't block the other socket. Control the plugs and the devices plugged into them with the Meross app. Or use Apple HomeKit, Amazon Alexa, or Google Assistant for voice control.
Meross dimmable multi-color Wi-Fi smart table lamp
$26.99 $45.00 Save $18
The intuitive touch controls on top let you change the color, adjust the brightness, and turn it on or off. Also works with Siri, Alexa, and Google Assistant for voice control. Includes several levels of tunable white and 16 million colors.
Meross Smart Wi-Fi Garage Door Opener
$26.79 $40.00 Save $13
Combine the code with the $10 off on-page coupon for maximum savings. Adds remote and voice control easily to your existing garage door opener and doesn't require any extra hub. Easy to set up with included tools. Get notifications and reminders.
Meross smart Wi-Fi garage door opener remote
$26.79 $39.99 Save $13
This garage door opener lets you control it using an app on your phone, or even with your voice and a compatible voice assistant like Amazon Alexa. Clip the coupon on its product page and use the following promo code to save $13 at checkout.
$49.99 $59.99 Save $10
Let's start with the Meross smart garage door opener going for $30.55 in this sale. That price matches an all-time low for this device. It's also the first time we've seen it go this low on Amazon since December. The smart device started as an Indigogo crowdfunding campaign back in November 2018.
It adds remote and voice control easily to your existing garage door opener and doesn't require any extra hub or anything like that. It's compatible with both Amazon Alexa and Google Assistant, and you can use the Meross app to turn your phone into a garage door remote control. You can get notifications that let you know whether the door is opened or closed, overnight notifications that help remind you to close it, and more. It comes with strong adhesive that you use to install it, making the entire set up process quick and painless.
You can also get four smart plugs discounted to $23.19 from a street price of $29. These plugs let you convert dumb appliances like a coffee maker or holiday lighting into a smart device you can control with your phone or by using your voice when you connect the plugs to your smart home ecosystem.
If you need to do the same thing but outside, grab the Meross outdoor smart plug on sale for $17.99 from $22. This can also connect to your home Wi-Fi and your smart home. Plus, it's waterproof so it can sit outside and power up outdoor lighting and other things like that.
