Make your garage door smarter for only $29 with this discounted device
Meross smart garage door opener
Meross smart garage door opener (Image credit: Android Central)
Getting caught up in all the different options of smart plugs and smart bulbs to add inside your smart home is easy, but don't forget your garage door in the midst of everything else. The Meross Smart Wi-Fi Garage Door Opener lets you add smart functionality easily, and today it's on sale for one of its lowest prices in history via Amazon. Simply clip its on-page coupon to save $22 and grab one for $28.55. Today's deal is only valid on the black model of this product.
Meross dual outlet smart plug 2-pack
$25.99 $34.00 Save $8
Create two outlets with one plug and a compact design that won't block the other socket. Control the plugs and the devices plugged into them with the Meross app. Or use Apple HomeKit, Amazon Alexa, or Google Assistant for voice control.
Meross dimmable multi-color Wi-Fi smart table lamp
$26.99 $45.00 Save $18
The intuitive touch controls on top let you change the color, adjust the brightness, and turn it on or off. Also works with Siri, Alexa, and Google Assistant for voice control. Includes several levels of tunable white and 16 million colors.
$26.79 $40.00 Save $13
Combine the code with the $10 off on-page coupon for maximum savings. Adds remote and voice control easily to your existing garage door opener and doesn't require any extra hub. Easy to set up with included tools. Get notifications and reminders.
Meross smart Wi-Fi garage door opener remote
$26.79 $39.99 Save $13
This garage door opener lets you control it using an app on your phone, or even with your voice and a compatible voice assistant like Amazon Alexa. Clip the coupon on its product page and use the following promo code to save $13 at checkout.
Smart Garage Door Opener Remote, APP Control, Compatible with Alexa and google Assistant, Multiple Notification Modes, No Hub Needed by meross - Upgrade Version
$49.99 $59.99 Save $10
By adding this smart device to your existing garage door opener, you gain tons of smart features, including the ability to open and close the door using an app on your phone from anywhere in the world. It also offers smart notifications and more. It requires a 2.4GHz Wi-Fi connection and is compatible most garage door openers out there, though you can check the company's site to ensure you can use it with your current garage door hardware.
The install is simple as your order includes everything you need to get it hooked up. In just a few minutes you can take one of the most basic features of your home and make it that much smarter. It's even capable of being controlled with your voice and a compatible voice assistant. The Meross opener works with Google Assistant, Amazon Alexa, IFTTT, along with Android and iOS apps, so you can incorporate it into your smart home in a myriad of ways.
Existing owners review this smart device highly, leaving it with a collective rating of 4.3 out of 5 stars based on over 550 reviews at Amazon. Shipping is free, though you'd receive your order even faster with an Amazon Prime membership. If you're not a member already, consider starting a free 30-day trial to score free two-day shipping, exclusive members-only discounts, and more.
