Upgrade your sound with $50 off Logitech's Z533 speaker system
The Logitech Z533 multimedia speaker system is currently down to a nice low price of $49.99 on Amazon. This system usually sells for $100 and has never gone this low before. It has never dropped below $80 before, actually. So this is a steal.
Logitech G Pro X Superlight wireless gaming mouse
$137.98 $150.00 Save $12
This mouse was made in collaboration with leading esports pros,, which means it's designed with intense and competitive gaming in mind. It weighs less than 63 grams. The Hero Sensor is designed for best possible performance.
Logitech G640 large cloth gaming mousepad black
$24.99 $40.00 Save $15
Gives the right amount of resistance to your mouse with low DPI gaming so you can be more precise. Surface provides a consistent texture for an even translation of mouse to cursor movement. Rubber bottom keeps it from slipping.
Logitech G613 Lightspeed wireless mechanical gaming keyboard black
$63.99 $79.00 Save $15
Includes Bluetooth and Logitech's Lightspeed wireless tech for a 1ms report rate. Uses Romer G mechanical switches that are very durable and can survive 70 million clicks. Has six programmable G keys and lasts up to 18 months on two AA batteries.
Logitech G305 LightSpeed wireless gaming mouse
$39.99 $60.00 Save $20
Includes Logitech's wireless USB receiver for a speedy connection. LightSpeed tech makes the responsiveness less than 1 millisecond. Includes a 12,000 DPI sensor, 250 hours of battery life, LED optical scanning, 6 programmable buttons, and more.
Logitech G502 Hero high performance gaming mouse black
$39.99 $50.00 Save $10
Uses high-performance 16K DPI sensor. Huge adjustable range as well. Has 11 customizable buttons with onboard memory so you can store different combinations per game. Has RGB lighting and LightSync to pair with other gear.
The Z533 system includes two speakers and one front-facing subwoofer with powerful bass. It produces up to 120 watts of powerful acoustics thanks to 2.25-inch full-range drivers designed with sound directivity. Connectivity includes a 3.5mm jack and RCA inputs, so you can connect just about any audio source including computers, tablets, smartphones, or your TV. All you have to do is plug in and start listening. The wired control pod gives you access to the power, volume, and bass controls. It even has extra jacks for you to use.
